Re: My hats off to those who teach
phillip Medghalchi
Mike, that was a very nice teaching, you did very well coaching him through it. I was concerned about two issues there. Even though that he started out staying out of line of fire at the beginning before the piece came to a full speed I, I noticed he move directly in line of fire in roughing out stage and he stayed there most of the time. I think in this stage is the most important time to stay out of line of fire like maybe to the right of the lathe towards the tail stock and have the tool rest tilted little more towards the bottom of the bowl so you are gradually shaping from the bottom up to the rim and blank steady itself little at a time and you are not in line of fire. and, also makes it easier to tighten up the tail stock as you go to have the blank staying put. Secondly, and most important that for a beginner you let him wear a full handed fingered glove around spinning blank on the lathe that it has been told is very dangerous. I am glad no accident happened there and you guys managed to finish the project, however, it's been noted by all the pros that you should not be wearing a full handed glove around the lathe. Unless you have had a long time experience around the lathe. He also, took his face shield off when he was working in the bowl trying to hollow it out and smoking. I am not personally a smoker, but I'd be careful around shavings of wood when the ashes form the cigarette keep falling out and he is not really shaking it off since he has his hands full with the gouge, so it'd dropping off on the shavings around him on the floor that can ignite wood.
I appreciate what you did for this young man and yes indeed teaching someone else is not an easy job to do, however, you did it well and more than likely he already got bit by the turning bug, believe or not. He is on the right track for a healthy hobby instead of getting involved with non-healthy alternatives of the activities. We all thank you.
