Spelling help
Spelling help
Spelling help
Mike Potts
do you spell it " spalded" or "Spalted " or something altogether different
thanks for the help
Mike
Re: Spelling help
Spalted
Re: Spelling help
Thanks Dick
Mike Potts
Thanks
Re: Spelling help
Re: Thanks Dick
Sergio
A dictionary, where is my dictionary....
Re: Spelling help
And it's tenon- not Tendon
Re: Spelling help
thank you John, that one drives me crazy!
Re: Spelling help
Re: And it's tenon- not Tendon
Dale Gillaspy
It is if you're talking about that little thing that holds your muscles and bones together.
Re: Spelling help
Mike Stafford
It's a spigot!
Mike Stafford
I prefer the English term of identification- spigot. :D
A tenon refers to flat woodworking and a spigot is a round cylindrical shape which is created on a lathe. See definition from Glossary of Woodworking Terms.
Spigot
A parallel projection on the end of a work piece which is made to fit into a recess of some kind, e.g. a socket in a chair seat or in a spigot chuck.
I hope that clears things up. Please, no blood or foul language in the discussion which is sure to ensue.
Re: Spelling help
Bill Blasic
Re: It's a spigot!
Bill Blasic
But Mike what if you have a tenon chuck? ;>))
Re: Spelling help
Re: It's a spigot!
Bob Macgregor
Is it no longer a spigot if the sides aren't parallel...as in shaped to fit the tapered chuck jaws?
Re: Spelling help
Re: It's a spigot!
Dale Miner
I thought a spigot was a device to dispense a beverage that had been previously fermented.
Re: Spelling help
Mike Stafford
Re: It's a spigot!
Mike Stafford
A spigot chuck by any other name is still a spigot chuck. :b Of course it is properly known as a cup chuck.
I haven't figured out an answer to the dovetailed sides to fit chuck jaws that are dovetailed. That shape certainly does not meet the spigot definition nor does it meet the definition of a tenon.
Tenon - is a projection on the end of a piece of wood for insertion into a mortise.
Mortise or Mortice - a cavity or hole (generally rectangular) in a piece of wood, meant to receive a tenon or a hinge
Re: Spelling help
Re:I have enough of a problem
Stuart Johnson
with that machine that use to cut turning blanks. Is it a bandsaw or a band saw?
Re: Spelling help
Correct! *LINK*
But works for most any liquid. Not to be confused with a "tap" which contains a spigot. This may explain why they prefer the stuff warm . . .
spigot
Re: Spelling help
Barry L Elder
Yes! :D
Re: Spelling help
Re: Spelling help
Craig Daymon
When all else fails, I just fall back to the technique used by Vizzini from, "The Princess Bride". Here's the clip from the script where he uses the technique.
Inigo: Look! He's right on top of us! I wonder if he's using the same wind we are using.
Vizzini: Whoever he is, he's too late. SEE? THE CLIFFS OF INSANITY! HURRY UP! MOVE THE THING! AND THAT OTHER THING! Pause. MOVE IT!
If you don't know the right term, "the thing", works in most cases. :D
Re: Spelling help
Dan Jechura
It's a finger shortener
Re: Spelling help
Mike Stafford
That's funny Lyle!  LOL
Re: Spelling help
Mike Stafford
A spigot is the less preferred name...
Mike Stafford
for a beer tap.
Depending on where one lives a beer tap is a valve, specifically a tap, for controlling the release of beer. While in other contexts, depending on location, a "tap" may be a "faucet", "valve" or "spigot", the use of "tap" for beer is almost universal.
Having worked as a bartender for one summer, this vast experience qualifies me as almost knowing what I am talking about with regard to the nomenclature of beer dispensing devices. :b :D
Re: Spelling help
Re: A spigot is the less preferred name...
Dale Miner
Having watched folk employed as bartenders from close range while setting on a stool qualifies me to not really care what the nomenclature is, as long as the fluid dispensed is cold and has just the right amount of foam.
Re: Spelling help
Mike Stafford
Dale, a perfect summary!  HIC!
Re: Spelling help
Re:just the right amount of foam
Stuart Johnson
Too many bartenders waste way too much beer pouring off all the foam. A nice beer that doesn't have lite anywhere near it with about 1 to 2 inchs of foam is just about right. I won't even start on the need for a menu when asking for a martini.
Re: Spelling help
Alan Zenreich
Alan Zenreich
... And it's a Morse taper, not a Morris taper...
