lathe spindle log tip
I have a total mental block on the gentleman's name that I stayed with in Virginia. I hope someone can tell me so I can give proper credit for this. I had a ball in his shop he had so many good ideas. This was one of the best. You know how hard it is to sand specific areas of natural edge bowls. I usually do it with the lathe off and will often put my index wheel on the lathe so I can index it where ever I need for proper sanding. This is faster and works great.
when you want to lock the bowl in any position just tighten up the top screw on the hand screw clamp. Loosen it to reposition and tighten it again. Fantastic. You can loosen it a little more and actually run the lathe with the clamp still sitting there. I love it. Works great.
