200+ woodworking book reviews
new American Woodturner
Just got it yesterday. Started reading it last night. Excellent article by Leon Olson on cleaning and repairing Morse tapers. The best tip ever was to use a 12 gauge shotgun cotton cleaning swab to clean the inside of the taper before inserting the morse taper.
Looks like it's going to be a very good issue.
Re: new American Woodturner
Dick Coers
I haven't read the entire article on CA as a finish, but on caption next to a picture says CA doesn't adhere well to metal bushings. Well I must be doing something WAY WRONG! I've glued bushings to the blank, and had to soak the bushings in acetone to clean them. I also didn't see any reference to cracking issues that have been coming up a lot more on IAP site.
Steve Kniffen
Dick,
If you rub a little paste wax on your bushings, the CA glue won't stick to them. Don't remember where I got the tip, but it works well.
Steve
Bruce Pratt
..including the shoulder of the bushing which contacts the brass and the end of the blank...
Wax works well as a resist for all sorts of glues. I've used it frequently for CA or epoxy to keep the glue from sticking to surfaces I don't want. I had to repair a cheap foam picture frame for a friend this weekend. It was black. I mixed up epoxy and dyed it black. Waxed the front surface and then glued all 4 corner joints. Used blue tape to hold it together while the epoxy dried. When it was dry I was able peel epoxy that bled out of the joint on the front side using my fingernail which left the frame looking like it was brand new and was probably stronger.
Josh_Bowman
I loaned mine out to a potential AAW member, thinking I could just read it on line. Only the June is up. When do they put the new on line?
Dwight rutherford
I was/am confused. I chose to get mine electronically and also see only the June issue available.
Well I would say you need to send the AAW a letter. It used to come out before I get my hard copy
Dwight rutherford
I asked about this yesterday and was told the electronic issue will be posted today.
