oscillating sander
phillip Medghalchi
has any one here ever fixed an oscillating sander which the spindle stopped oscillating up and down?
oscillating sander
phillip Medghalchi
Re: oscillating sander
My Rigid combination spindle/belt got sideways, but when I got into it the motor and oscillating gear were a one piece deal. Fortunately it was covered by the Rigid warranty so I put it back together and dropped it at a repair facility and 2 weeks later I had my machine back with a whole new motor/gear unit installed. The guy at the shop told me they just replace them because it's cheaper, labor-wise, than stocking the parts and trying to fix it.
What brand are you talking about? If it's Rigid, you should check your manual for the warranty as some of them were pretty long
phillip Medghalchi
Mine is Ryobi, and it won't be under the warranty. As a matter of fact they are discontinued and only parts you can get for them is screws and such. It's just a shame that all of a sudden it stop oscillating.
Phillip Medghalchi
WSell, i took it to the elelctric motor repair shop and he said that the belt was broken and the bearings need changing. He wants $165.00 for it, any one else have any other suggestions, has any one done such a repair that can be doen for less than what he wants?
Re: oscillating sander *LINK*
Stuart Johnson
I doubt if the bearings being bad would stop it from oscillating unless they are completely frozen. Even then they would have been making some loud noise for a while. Check to see if the part will turn by hand. If the belt is broken see if you can't replace it yourself. The price you were quoted seems high for just bearings and a belt. I've included an EBAY link for belts.
Ryobi OSS belts
Don McLeod
I see that Sears has a parts diagram for the ryobi OSS450 sander and carry some parts in stock.
http://www.searspartsdirect.com/Ryobi-Sander-Parts/Model-OSS450/0909/0743000/P0511010/00001.html
