Have a question? Ask Woody!
cold bending wood *LINK*
I'm just starting to play with this stuff and see what I can and cannot do with it. Have a long way to go. It's challenging. This morning and last night I played with making 3/8" dowels of about 10" long. Fed the wood through my Lee Valley dowel making jig. It started out OK but then twisted the wood in half.
then I tried my old tried and true homemade router jig for making the dowels. The wood is too flexible and the cutter bounces it back and forth and makes it look like bad chatter. It also wanted to peel the wood making it hard to feed.
then tried turning it between centers. I turn wood this size all the time and can usually do it with minimal chatter. 1/2" square by 10" long. This stuff is so flexible it wants to climb the blade. I supported it with my hand as best I could but simply couldn't turn it. This was Ash by the way.
Then I tried sticking it in a chuck so only 2" stuck out. I was able to turn it down to a little over 1/8" thick. I kept extending about an inch or 2 at a time and after I broke the first inch or so was able to turn it down to that size for about 4 " or so. Below is a photo of how much I was able to bend the elbow before it started cracking. I have tried this same thing with lots of different wood and they break before 90 degrees with that sharp of a turn.
I had one piece left from the morning cutoffs. Since the wood tried to twist when I fed it through the router and lee valley tools I decided to see if I could twist it like I do with square stock when Blacksmithing. Worked pretty good. Just started to crack in the bottom of the twisted flutes when I got it this far. It sprang back about. 3/4 to 1 turn. Dried enough to stay in this twist after 2 hours.
Still have a lot to learn but it's interesting stuff. Here's the website if you want to learn more or buy some for yourself.
http://www.puretimber.com/small-orders-and-samples/
