Wall mounts for platters or art pieces
I made a few of these over the years but they need work. The idea is the compression spring pushes the 2 dovetail parts into a dovetail in the platter. Screw the bottom one to the wall and then put the platter on by pushing down from the top. When you release the tension the bottom one snaps into place and holds the platter to the wall. To get it off just push down on the platter and pull the bottom out.
They need to be either smaller than the dovetail when squeezed together of narrower like the one on the right.
the problem I'm having is getting it to work smoothly. First of all of course you have to drill the holes perfectly square to the edge and parallel to each other and of course the spacing has to be dead on. The problem (and it's really kind of minor) is the two parts don't move smoothly. I've tried polishing the rods and waxing and it only works moderately well. Maybe there needs to be a metal or plastic insert for the rods to move in.
Anyway, play with this if you wish. I obviously don't have time right now.
Re: Wall mounts for platters or art pieces
Thanks John
Mike Potts
Very inventive idea, but at this point I don't use dovetail on my plates. sure will keep this idea in mind for the future
Thanks
Mike
Joe Herrmann
Maybe if the holes for the rods were just a tweet larger in diameter??
barry rockwell
Barry Rockwell
John, how about if each rod had a spring coil over it? Seems like it would relieve some of the alignment issues if they worked independently.
The solution is using 2 springs.
Steven Antonucci
And at the outer edges(not centered), methinks?
Re: Seems like the top should be secured to the wa
Steve Criscenzo
I like the overall idea and then using two springs over the rods. I also think that it would work better if the top was secured to the wall rather than the bottom. That way, the weight of the piece is held by the screws and it cannot move. A provision would need to be made to keep the bottom attached to the top while mounting but that should be easily accomplished.
Steve
Steve If the wall hanging was really heavy it might be a problem having the loose part on the top but you could overcome that with a stronger spring. If you turn it over the bottom falls out and you would have to somehow capture it. Not a major problem but If you pick the right spring the top mounting should work for most things.
I'll try the 2 spring approach some time
It may work or the rods may contact the individual coils and stick a little like they do now on the sides of the holes. I thought about inserting brass tubing that is a sliding fit over the rods. That and a little bit of dry lube would probably work.
