Walnut cold bend mirror
This is more use for the Cold Bend wood. The handle was cold bent and then carved. I left the textured streaks from the rotary carving burr. The mirror body was regular walnut and then finished to a polish.
Re: Walnut cold bend mirror
Craig Daymon
Looks good.
Looks like it might make a good prop for the next Harry Potter movie too. Maybe carve a little snake's head on the end of the handle?
Cool, John!
GaryG in MD
These have real class and style. Outstanding.
I agree they could be in the movies. Call John Lucas!
Or Spielberg!
These would look great in some real high-end galleries.
Whatever you're charging, increase it by a factor of ten and hit the big city markets! Seriously! ...GG
the pins were a pain
Gary you mentioned using more pins and that's what I did in this mirror. It was a pain. I marked and drilled as accurately as I could but they were off just a hair. Maybe not even a hair because a hair is 4 to 5 thousandths. It was off just enough that lining all 3 up was a pain.
Since I wanted them inserted from the inside and not show on the outside I had to drill the holes extra deep in the mirror. Then I drilled a hole sideways with a forestner bit to allow the long pins to go in further than normal. This way I could line everything up and push the pins from the mirror inside into the holes in the handle that had some epoxy in it. Then I added CA glue to the inside holes.
To mark the holes in the handle I sharpened the Brass pins and turned them around backwards so the point stuck out toward the handle. I held the handle in place and pushed the pins out to mark the handle. The pins were turned around for the final glue up.
The mirror glass will cover all of this up.
WOW - great work!
Re: the pins were a pain
Craig Daymon
Not sure if it would assist with the alignment of the holes, and I'd definitely run a test first, but how about creating a grooved V-block to mount at the headstock to seat the disk in, put a jacobs chuck in the tailstock with the right bit and use the lathe to drill?
As long as the V-block is properly centered, you should (in theory) get a proper hole.
(Yeah, definitely try it first before committing to it.)
Anytime you need more expertise from someone talking out his backside, just let me know. ;-)
The V block only works on the head. The handle isn't a perfect circle on the outside so I had to level it by eye to drill the holes perpendicular on the inside of the handle. I was really really close but when the fit that tight it made a difference. I use a V block on the drill press to drill the holes in the mirror head but had to use a vice to hold the handle. The sharpened pins acted like a dowel locater and marked the center but i had to align the handle by eye to get the holes parallel to the line from the mirror body.
Dave Turner
Dave Turner
Could you make a temporary filler block out of your Cold Bend wood that would go between the handle and the mirror body where the pins are located. Double stick tape the filler to the mirror and drill your holes thru the filler into the mirror. Remove the filler from the mirror body and double stick tape it to the handle. Now you have a guide for drilling the holes in the handle.
You can't drill from the inside of the mirror, no room for the drill.
Dave Turner
Dave Turner
You don't have to. You drill thru the filler into the mirror. Remove the filler from the mirror. Mount it on the handle and use the holes in the filler as guides for drilling the handle.
Gottcha, thanks
Impressive!
Don Orr
Hanging around all those artists all these years must have rubbed off on you! But you have always been creative on your own and it sure shows here.
Love the tension, and the contrast between the smooth/shiny and textured parts.
