THE WOODRAT IS BACK!
Filling holes in finish
When I'm doing a glass type finish I typically spray on layers of finish and sand them down until all the holes and pores in the wood are filled. Sometimes you have one that is particularly deep and won't fill without many many layers.
What I do is add one drop of finish to the spot. let it dry. It won't sand down without lowering the surrounding area so I scrape it flush with a Razor blade.
Then sand and apply another coat and that usually does the job. If not I'll do the whole process again.
You can see in the final finish the knot is now filled.
Re: Filling holes in finish
good tip
GaryG in MD
I'll sometimes use CA for that. (Before the first coat of finish.)
It dries a lot faster. The sharp scraping method works great for that too.
You can also do the same kind of thing to reset a "point" (like your tail center) if you only want to move it a small distance -- so small that the new point would merge with the old point if you tried to do it without fixing it first. I just fill the old hole with medium CA a couple of times and lightly accelerate with an aerosol (not pump) after each coat. You can reset your point safely in a couple minutes.
...GG
Done the same in flatwork but used a freshly honed and burred card scraper that I put a very slight curve on the ends to prevent the corners from scratching a deeper line in the finish film.
Mark The razor blade is like a really mild scraper. If I'm doing this on a flat surface I will just use the blade and you can flex it like a card scraper to get a more rounded cut.
I do use CA glue as the initial fill and most of the time that works. However sometimes when you start spraying you find another hole that didn't look that bad at first. This is where the lacquer dot comes in.
Gotcha. I've used tinted shellac to fill dings in older acrylic finishes on cherry. Takes a few drops but with a bit of careful scraping and repolishing they blend in as sap pockets and nobody's the wiser ;)
Good tip!
David Walser
John - Just FYI: Years ago I worked in a furniture mill. For about six months I inspected and repaired (if necessary) each piece of furniture before it was boxed. For a small hole or dimple in the lacquer, I used exactly the method your describe. After a final polishing with rotten-stone, no one would ever be able to spot the repair.
This is one of the great things about a lacquer finish. Each coat melds into the prior coats, so you cannot see each layer as you can with some other film finishes.
