Veritas - Innovation in Tools
Mini lathe recommendations?
Warren White
Good morning!
I am new to the turning side of things, but I knew this would be the place to ask a basic question or two.
I would like to buy a mini lathe, mostly for turning pens and other small things. I have no experience with such, and so I don't even know where to begin. I have around $600 to spend, and would like recommendations for the lathe, as well as the needed accessories. I have a friend who could help me with sharpening tools. I doubt that I would want to upgrade to a larger lathe for the really big spinny things, but I do note that some lathes have extensions you can buy if the bug grabs you and you can't let go.
So, what are your recommendations, and what should I look for when I buy. What options, etc.?
My thanks to each of you!
Warren
Re: Mini lathe recommendations?
Re: Mini lathe recommendations? *LINK*
Peter Hyde
Rockler are advertising a Nova Comet with electronic variable speed for $499
Has to be one of the best deals out there for a midi from a reputable company. Not much left in your budget for tools and other necessities but usually local turners and clubs can provide some at bargain basement prices .
Comet
The Rikon from Woodcraft is a good lathe with a good reputation and should leave you enough cash to buy some tools.
http://www.woodcraft.com/Product/2005508/16400/RIKON-Mini-Lathe-Model-70-100.aspx
Dwight rutherford
Buying a good used lathe would be something to consider . Craig's List or contact a turning club nearby.
Terry Scott
My recommendation is buy a lathe 10% more than you can afford
Maybe a hardship but you will never regret the extra expense
Plus it wont be long that you start selling a few smaller items which will help fun your addiction
Quality of chisels is also important steel has come a long way since the Sorby carbon steel days so make sure you get HSS
You can pick up second hand lathes and gear but id suggest talking to a woodturner in your area to check it out as there is a lot of crap available that wont do you any favors
Join a club this is the best way to get free advise
Cheers
Barry L Elder
Your $600 should get a reasonable lathe, but the tools and various accessories will probably cost another thousand or two! :D
David Walser
Welcome to the world of woodturning. If all you want to turn are pens, bottle stoppers, ornaments, and similarly sized projects, I suggest you consider the following:
* Apprentice 812 VS Mini Lathe from Craft Supplies USA (CSUSA) $200
* Apprentice Pen Turning Starter Kit, also from CSUSA $160
The lathe is small and would not be appropriate if you wanted the ability to turn an occasional bowl. (The lathe has an 8" "swing", the maximum diameter blank that will fit on the lathe.) However, for pens and other small items it will do all you want or need.
The starter kit contains the turning tools, mandrels, kits, and other items you'll need to make your first 10 pens. It also comes with a very good DVD that walks you through the process of making a pen. In addition to the lathe, all you'll need to provide are a drill press (for drilling the pen blanks), a saw (to cut the blanks to length), and a clamp or vise (for pressing the pen parts together). The kit comes with glue, finish, and sandpaper.
After your first 10 pens, all you'll need to buy are more kits and blanks. Of course, you may quickly wish to try your hand at larger projects, in which case you'll need a lager lathe. People have already warned you about that definite possibility.
Good luck!
Apprentice lathe
Joe Fleming
Joe Fleming
Warren,
If $600 is your budget for lathe and tools, you are going to be pinched. Here is my recommended basic five tool set (with some approximate prices picked off of Craft Supply's website):
1 - 1/8" parting tool, flat blade, not the diamond - $40
2 - 3/4" roughing gouge - $55
3 - 3/8" spindle gouge - $33
4 - 3/4" skew with square edges (better for rolling beads) - $45
5 - 3/8" bowl gouge (1/2" bar) English tool companies call this 3/8"; American tool companies call this 1/2" - $55
6 - Optional - 3/4" half round scraper - $39
Lots of quality choices for tools. None come from Harbor Freight. Consider Packard (made by Hamlet), or Artisan from Craft Supplies (made by Henry Taylor).
Additional necessary stuff:
- Full face visor
- assortment of sand paper
- grinder with one aluminum oxide wheel (white)
- dust mask for sanding
- maybe an oil finish for starters
If you shop hard, the above stuff will bring you in around $300. Woodcraft is having their annual Anniversary sale this Friday and Saturday. Turning tools are 15% off, I think.
Rikon is a good choice for a basic lathe to get started.
Joe
Also check IAP *LINK*
Jeff Willaford
In addition to the great recommendations here you might also check the International Association of Penturners website.
http://www.penturners.org/
Scott Greaves
Since no one has mentioned it yet, I like the Jet mini. I have had one for a number of years without a lick of trouble. Since they have been around for a while, you might get lucky and pick one up off of Craig's List used. I'm not saying it's better than the others suggested, but it is worth considering. Have fun!
Scott.
+1 on the Jet mini
terry quiram
I turned for many years on a Jet mini. Make sure you get a VS lathe. You will get tired of moving the belt to chg speed very quickly.
Ditto on the Jet
they are fairly easy to find on craigs list or ebay and they have a good reputation. I have owned a couple of them along with one Rikon and the older Nova Comet. All good lathes.
Re: Ditto on the Jet
Warren White
Thank you all for your suggestions and encouragement. I have found a Jet on Craig's List; a 1015 VS for $450.00. The owner wants to upgrade to a larger lathe, and has only used this one once. From the picture it looks pristine.
I will drive up there today and most probably pick it up.
I think I will post here again and see if there is a turning club in the area. I will also most probably be posting dumb questions on this forum from time to time, since I really don't have a clue about this new undertaking.
Thanks again!
Warren
Dwight rutherford
The easy way to find a club in your area is to go to Woodturner.org. There is a feature called " Find a chapter". It will display all of the AAW clubs.
