stack laminated mirror
I was having fun playing with this one. The handle is stack laminated with 22 layers. The mirror has 2 layers with the Walnut stacked on top for the rings.
Re: stack laminated mirror
Mike Stafford
John, your mirrors are works of art. You just keep raising the bar. Lovely!
Craig Daymon
Looks like you're definitely having fun.
Looks good and fun to make.
Does the rod connecting the mirror to the handle (or rod segments as I suspect it isn't a single rod) allow the mirror to pivot?
I'm currently working on 2 mirror projects that both involve adjustable angles to the mirrors. One is convoluted, but simple mechanics. The other is going to require some sort of pinching adjustment to lock in position. I'm still germinating the best way to do that.
No bent lamination involved. Wish I could, but I have neither the space nor the equipment. I'm very envious. Lots of bent lam projects piling up on the mental shelf.
Craig Daymon
Speaking of mirrors, have you seen the movie, "Tim's Vermeer"? Great movie and very interesting. Mirrors are central to his ability to create the painting and not only could you create your own custom mirror rigs for the job, but also possibly apply the technique to paint pretty much anything to a Vermeer quality on the backs of some of your mirrors. (I'd definitely stick with relatively small images as it took him several months to recreate his version of a Vermeer masterpiece.)
Craig this one is glued in place but I'm worried that people might force it. If they do it will probably move and then the pins might work their way out. I still might drill through the side of the pins and put a very small brass pin in to guarantee they won't fall out.
I have made several swiveling mirrors in small stands to go on a dresser. I just use 2 screws as the pivot point. Tighten them up enough and the mirror will swivel and stay where you leave it. I might take the time some day to work up a better system.
On system I did work on but haven't taken the time to make a full scale version is a ball on a stand. I will put some steel inside the ball that holds the mirror and a magnet in the stand. Then whereever you rotate the ball it should stay. I hope.
Eye of Sauron
wow
GaryG in MD
That looks like an Egyptian hieroglyph to me.
And that's a compliment! Great work! ...GG
Craig Daymon
One thought for the pins on this mirror design is maybe consider using 2 pins equally spaced about the center axis on either side. That would remove the possibility of rotatiion.
I like your magnet and ball idea. I do have a few half and full sphere rare earth magnets. Not sure if they are large enough for the mass, but they could be helpful.
I might try something with theaded inserts in adjustment knobs for a pinch clamp to position it.
Thanks.
Watch for my next mirror in about 2 days or less
Jim K from Trappe PA
Beautiful!
Awesome!
Don Orr
Out of the box for sure!
