Re: Using walnut oil or tung for sanding
phillip Medghalchi
Wally, thank you for replying. Let me ask you if this procedure only works for the oil finish? That you have to use the same oil which you would finish your final finish with? Or, let's say I want to apply this method and then use General finish salad bowl finish to finalize the finishing process, would it work or the salad bowl finish will not adhere to the previous oil which is soaked into the wood?
I understand that by doing this you use the slurry and fill the little holes and the end grain areas and also, the wood gets replenished with the water it lost during turning process, am I thinking it right?
I once saw a guy on you tube that he used tung oil on a piece of spalted pecan then he finished the piece by applying sanding sealer and lacquer, I emailed him about it and he has not responded yet, so I think my thought on lacquer use is not correct?
