Sanding disk post
phillip Medghalchi
Robbo (Reed), you wrote:
"Phil, I was wondering why our experiences with Vince's Blue discs are so different. Maybe the soapy water is the reason. I typically can get a 3 bowl cored set (14, 11, and 9 inch diameters) done with one set of discs. The 80 grit does flake off a bit, but not really a problem. I have had no issues with 120 and above losing the grit off the plastic film. I have wet sanded with walnut oil, but didn't like that, too messy, and the discs loaded up with sludge. I do soak my bowls in soap water first, then let them dry, and then sand".
Reed, I have not set up my sanding hood like in your video, which I will contact you about it, yet.
I figured it on my own that when I spray soapy water on the piece when i start at rougher sand paper that first of all it doesn't create that much unbearable dust and then I reverse sand with every grit and have been able to get a much smoother surface with them. I only do this up to 180 grit after that it's less dust being created and I can go on with the rest of the grits. Wait until I bring you some Mesquite wood when I come up to WA, then you will see that the darn thing is very fine dust and lots of it too, just like the way you described in your video about sanding walnut.
