Revolution time
Revolution time
Dennis in Southern Oregon
Revolution time
I was doing a bit of spindle work yesterday in preparation for a club demo and it occurred to me that I seldom see a posting in WC related to spindle turning and rarely see a picture of someone's work. On the face of it that seems a bit odd since it would seem that number of spindles turned far exceeds all other turned items. A quick count in my house came up with 151 spindles (not counting pens and not counting spindles that I have turned). Furthermore, I would expect that most homes not inhabited by woodturners or collectors would contain no more than a dozen or so woodturned objects. Clearly this is a wrong that must be righted!
Come on spindle turners, it is time to unite and throw off the tyranny of the container turners! Post Post Post.
Dennis
Re: Revolution time
Re: Revolution time
Depends on what you call a spindle. I of course have a spindle on every mirror. Do boxes or goblets count as spindles. On all the sites I frequent I rarely see spindles or even project with spindles. Bowls and hollow vessels seem to be the most posted. Maybe that's simple because people don't post the spindle items they turn.
Re: Revolution time
Keith Tompkins
Re: Revolution time
Keith Tompkins
HI Dennis, I'm doing a spindle commission as I write; it's for a staircase restoration. I've come up with some new tricks, and took the advise of Jon Seigel. If you haven't heard of him, he's the founder of the New Hampshire Guild of Craftsmen, and probably the best spindle turner I've seen. (You can google him) His method is to turn just one element of a spindle, then repeat the process on the entire batch. For example, turn a bead on all spindles, then turn the next element, say a cove, on the entire set. This is the first time I tried it, and I must say, it is a superior method to turning each spindle from beginning to end. I'll post images and details when done.
Re: Revolution time
Re: Revolution time
phillip Medghalchi
Dennis, no disrespect to keith, I think the thing is that with bowls and boxes you can get quite creative Vs. with spindles and then when yo are making goblet and vine glasses and finials they are spindle work and the turner doesn't just come around and post them here as separate turnings.
Re: Revolution time
Re: Revolution time
Keith It would seem like removing the spindles and putting them back on each time would eat into the total turning time. That's interesting. The last time I did a small production run for a client the first 5 were kind of slow but after that I had all the movements and cuts down and just turned each one. They went really fast.
Re: Revolution time
Steven Antonucci
Way more face grain work here than spindle
steven antonucci
Even if I counted the balusters and all of my tool handles, I think just the bowls outnumber the spindles 2-1. In general, a spindle is more likely to be a part of something instead of the entire thing itself. There is also much less interest in the post turning decoration crowd...
Maybe I will go make a set of candlesticks...
S
Re: Revolution time
How many lathes you ue Keith?
Jorge
to turn a bead and then a cove and... in an entire set, a lot of time goes to mounting an dismounting the spindles. I have done quite a few stairs It is not hard to do spindles that look the same in a reasonably short time, about 12 min for me, 7 for my mentor.
Re: Revolution time
Jim Barbour
Does this count?
Jim Barbour
Re: Revolution time
Keith Tompkins
Re: Revolution time
Keith Tompkins
John, Like Jon, I use a stebcenter, and switch spindles without turning the lathe off. Sounds dangerous, but it's really not since the tip is spring loaded. It's the first time I've tried it this way, and I surprised how well it works.
Re: Revolution time
Re: Revolution time
Steve has the answer of course. Most spindle turning today is an automated production process associated with the manufacture of furniture and building supplies. Although my post was mostly tongue in cheek, I do admire good spindle work and I think that it is an art form in itself. I would enjoy seeing more examples posted here. Never mind that its use is mostly utilitarian rather than pure art. Remember, Michelangelo's mural in the Sistine Chapel was there only to hide the cracks in the plaster! They could have used wallpaper instead.
Dennis
Re: Revolution time
Keith Tompkins
Re: How many lathes you ue Keith?
Keith Tompkins
Hi Jorge, I have three lathes, but my big General does the bulk of the work....I've known about Jon Seigel's methods for some years, but this is the first time I tried it. He does mainly production work, and feels his method is more accurate and faster. I agree on the accuracy part but wasn't so sure on the speed. So far, I think he might be right.
Re: Revolution time
Jorge
I never did stairs with a steb center, I'll try it next time
