Veritas - Innovation in Tools
round picture frames plans
gary clarke
does anyone have any experience making round picture frames? Any plans available or web sites that would be helpful? thanks in advance.
Re: round picture frames plans
Dwight rutherford
I made some large ones (20" diam.) years ago but used a router and circle cutting jig. Depending one a lathe's capacity, you could attach the frame wood to a face plate made out of MDF. Turn the back then reverse and turn the face profile. I'd check out U-Tube.
what size
I made 50 oval ones years ago using the router. It would be just as easy to make them round. I have made several over the years using segments and turning them on the lathe. I either hot glue them to a backer board or I did a few by gluing a cross of scrap wood onto the frame. If I remember correctly I glued the cross to the good side of the frame, then trued up the backside and turned a rabbit for the glass. The cut another cross that was glued to the rabbit and center bored it so I could turn the frame around and turn the outside. Not the best way to do larger frames because you get too much chatter. The backer board works much better.
Re: what size
Gary clarke
Thanks for the ideas,I will be making some 4 to 7 or 8 inches.
Re: what size
Gary I have an article coming out in Vol29 Issue 4 of american woodturner that will show how I glue wood to waste block discs turn rings. The article is about making half ring candle holders but the methods I use are the same.
Basically I center the blank as best I can on a large wooden faceplate and put hot glue around the outer edges. Face off the piece and then turn the inside shape including a rabbit for the glass. Turn part of the outside (but don't cut through the glue of course). Then remove the piece by cutting away the glue. I use a box cutter to do this. You could probably use double stick tape for this however sometimes my glued up rings aren't perfectly flat and the hot glue allows me to go ahead and stick it down since I'm going to turn both sides anyway.
Now I add a second waste block to the original faceplate disc and turn this down to fit the rabbit of the picture frame blank. make the rabbit tenon short enough that the frame sits on the original wooden faceplate. Think of this as a sort of jam chuck. Use double stick tape to fasten frame to the faceplate and turn the rest of the picture frame.
I have some jumbo jaws and have used them to turn the backside of things like the picture frame. Then gone to the wooden faceplate with jam chuck to turn the good side of the frame.
Re: what size
Gary clarke
John, great idea, looking forward to reading your article.
