Thousand cankers
Thousand cankers
Thousand cankers
Don Jacobs
Would it be safe to process infected walnut logs and bring them into the shop?
Re: Thousand cankers
Bill Boehme
Depends on where you got the wood and what you mean by "process". Have you looked at this site: http://www.thousandcankers.com/ or some of the others that you can find if you Google "thousand cankers"? There is a map on the provided link showing the 2013 survey of locations where the disease has spread: http://pest.ceris.purdue.edu/map.php?code=FDAAGFL#
If you got the wood from an infected area then it might be risky to use it.
Is a fungal disease being spread by the walnut twig beetle that disrupts the tree's vascular system causing the tree to die from the crown down. While a number of effected areas are embargoed making transport of the raw wood outside the quarantined area illegal as well as unethical, you may still use the wood, locally to the site of harvesting, to turn and make into finished products. IIRC you can also harvest the wood, saw it out, and "export" it provided that it is kiln-dried with an appropriate program of heat treatment. To confirm this check with the links Bill provided along with your county or state forestry offices.
If your concern is bringing WDI's into your home/shop, relax, unless, of course, you happen to live in a walnut tree. ;)
Don Jacobs
thanks for input. Tree belongs to a neighbor here in Denver. Plan would be to cut some sections for turning blanks and slab some for flat work.
Doug Trembath
Whatever you do, please use the appropriate discretion, in order to honor the place that American Black Walnut has earned in the history of woodworking. Having earned a great appreciation for this timber over forty years of woodworking, my heart aches to see it threatened by this disease.
No other timber, in my estimation, reaches the depth of emotional grasp for even the most unsophisticated of viewers. The Black Walnut evokes an almost spiritual response, even to those that aren't conversant with the differing species of American hardwoods. The varied grain patterns, and the majestic chatoyance of a tree given the time to develop the changing grain patterns and visual interest that only time can evoke, over the decades, gives even those who know nothing about wood an almost religious response. Turn some pieces from an old Black Walnut tree, do it justice, and exhibit them. See what I mean in the reactions of the folks who view them. The tree which has stood as a test to time, despite Man's supposed progress, stands as a true monument to Nature's intent, to create beauty you can't even see until you destroy it.
Something about the remarkable grain features, and the warmth and welcoming friendliness of this timber evokes a special reverence, that cannot be overstated.
I have spent many a day showing my work. Believe me, I have seen the base emotions Black Walnut evokes. I believe the tree demands protection, and if that fails, it certainly demands respect, even devotion, which I, personally, am more than happy to provide, as can be seen from my diatribe...
Doug Trembath
