200+ woodworking book reviews
Desk leg copying
Desk leg copying
Desk leg copying
phillip Medghalchi
My next door neighbor, showed me a desk which is solid and was made somewhere in the 1924's which his Mom bought for him as a new house warming gift. It has these huge out of proportion legs at the bottom that resemble huge round disks and somehow they don't match rest of the design. he complains that the height of the desk is not right for him, so he asked me to turn for legs for him to his height. Fortunately, the desk is made of red oak and stained very dark which he is going to re-stain it. since I usually do bowl turning and never had to copy something to the scale twice, my qsn. is how do I copy them exactly so they won't be off and what would you charge this guy to be neighborly and not over whelming? I do not want to do it for free since it's going to take me sometimes.
Any help will be appreciated.
Re: Desk leg copying
Re: Desk leg copying *LINK*
terry quiram
They don't have to be exact matches just close. I use a measured drawing and calipers. The link will give you an idea of what to change. You have to drill down to get prices.
Table legs
phillip Medghalchi
Dwight, Terry, I appreciate you two's suggestions, however, i am looking to design something for him new then copy them another three times to become 4 feet, my apologies for using "legs instead of "foot". I am trying to find out what's the easiest way to copy exactly three times off my original design. I am not sure if I want to spend the money to buy the duplicator for this job yet.
John lucas
It's just a matter of taking it slowly and measure it carefully very gentle shear scaping is a good way to really sneak up on the final shape. Balls and beads are the hardest things to copy exactly. Coves and V's and ogee shapes are not difficult.
phillip Medghalchi
Thank you John, I try your reply, while holding my fingers crossed. I am sure with you all's help I am going to pull it off.
don stephan
With a full sized drawing, devise a plan to turn one from start to finish, perhaps making a test piece in poplar or other workable wood. Make brief notes of sequence and tools used. Then follow your notes for each one in turn. As already stated, they don't have to be perfectly identical.
William Duffield
First, make an extra one, then when you're done, pick the four that are closest in size and shape. Just knowing you have one extra will help you relax while you are turning and get the job done faster, more accurately, and with less stress.
Second, make a pattern, out of thin stiff material (e.g. doorskin, hardboard, MDF, etc. that you can rest on the tool rest and transfer marks for all the critical transitions to the rough turned blank using a pencil. After you've marked the blank, hang the pattern up directly behind and above the piece you are turning for quick reference.
Third, it helps to have several pairs of dividers, one set to each critical diameter. They need to be marked or labeled so you don't get them mixed up. I like to stick them to the front of the lathe bed with small rare earth magnets. Don't leave any sharp points or burrs at the measuring end, so they won't catch in the turning wood. I usually make a half pattern, so I can't take the diameters directly off the pattern if I need to turn some more later to the same shape. Instead, at each critical point, I measure the matching diameter horizontally and mark and label the other end on the straight side of the pattern.
I've turned lots of spindles, many to reproduce antique architectural parts like balusters, and I've never used a duplicator.
