ADVERTISE HERE - FREE TRIAL
How long does it take...
GaryG in MD
for Deft to cure fully?
On the can, it says "dry to the touch in 30 min." and
"recoat in 2 hours", but it doesn't say how long to wait before sanding or buffing.
I can tell you that it's longer than 24 hours. DAMHIK! ...GG
Re: How long does it take...
robo hippy
Well, it is pretty dry after 24 or so hours, but can take a week or more to totally cure and off gas. If you can still smell the solvents, then it isn't cured. Ventilation as in a fan, or an incandescent bulb a ways under it so a small thermal flow starts can hasten it up as well.
robo hippy
Thanks, Reed.
Mike Stafford
Mike Stafford
I always thin lacquer based finishes 50% and that helps them dry faster so that multiple coats can be applied in a shorter time. I apply the finish with a brush, wipe off the excess with a paper towel and then 'dry' with another paper towel with the piece under power. I then rub out/even out 'dry" coats with a cheese cloth or steel wool or very fine 3M woven pads before applying the next in order to remove any dust motes or runs that might show up.
When enough coats are on the piece to suit me I let it dry for a day or so before buffing.
John lucas
Back when I used to use deft I found that I had to wait at least 3 days before buffing. If I did t I would burn through it very easily. I switched to a commercial grade lacquer and it cures much faster.
Mike Stafford
Me too!
Mike Stafford
I am using Qualalacq brushable lacquer which is different than Deft by the way.
Dick Coers
Non aerosol Deft used to have retarders added to it for more flow out time to limit brush marks. No idea if that is still true, but makes sense why other lacquers cure faster.
Mike,
GaryG in MD
Of course, the can says "Do Not Thin".
Why would they do that?
Just to make you use it up faster, I suppose? ...GG
Thanks, John,
GaryG in MD
All I know right now is that one day is NOT enough.
Thanks for the ballpark and info. ...GG
good info
GaryG in MD
Thanks, Dick. ...GG
Mike Stafford
Re: Mike,
Mike Stafford
I use their proprietary thinner and that allows me to not follow the directions. I have been doing it for years with great results. IMHO of course. Your mileage may vary.
Re: Mike,
phillip Medghalchi
Exactly, just that. 8)
return question
GaryG in MD
How do you think brand-x lacquer thinner would work?
Any idea? Heard anything? Thanks, GG
Mike Stafford
Short truthful answer- I don't know
