Chestnut & Walnut Wood Available
Jerry Klug
Anybody near Oliver, B.C that would like some Chestnut or Walnut wood? My sister is going to have some mature trees cut and would like some of it to go for a better use than firewood.
Re: Chestnut & Walnut Wood Available
walnut should not be moved...
GaryG in MD
from one location to another because the species is being decimated by Thousand Cankers disease, and moving wood to a new location spreads the disease. ...GG
http://www.thousandcankerdisease.com/
Re: walnut should not be moved...
darrin hill
so if someone 20 miles from oliver bc is a turner, does that mean he shouldn't get the wood?
what if you cut it, spray insecticide all over it, seal it in plastic trash bags filled with mothballs, and keep it sealed for 5 years… then turn it.. is it still not moveable?
Re: walnut should not be moved... *LINK*
walta
Walnut has a problem with Thousand Cankers Disease.
This disease is the result of the combined activity of a fungus (Geosmithia morbida) and the walnut twig beetle (Pityophthorus juglandis).
So insecticide is not a good solution, as you could still be spreading the disease.
Many fungus spores are still viable after being dormant for decades.
It is a bad idea to move walnut even if you are not crossing a quarantined area.
I think the last mature chestnut tree died from the blight in 1940s.
Walta
thousandcankers.com
'Nuff Said
