Will acrylic and acetone penetrate punky wood?
Craig Daymon
I know you can mix acrylic shavings with acetone and, typically using a vacuum chamber, it can be used to stabilize blanks. (Mostly pens, otherwise the chamber gets very costly.)
If I keep the mix thin, more acetone than acrylic, will it penetrate into a larger blank?
The particular blank is very dry and not so much punky as just very prone to tear out, with some deterioration from spalting. Though still very solid. (And lots of curl.)
Really want to get a clean surface out of this, and there is another half of this blank that I'd like to make good use of as well.
Thanks.
