New Wood Pile
New Wood Pile
Allan W
New Wood Pile
Allan W
My newest collection of wood for turning. Helped cut down an ailing maple at our church and brought this home. Now I need to figure out what to do with the larger chunks.
Re: New Wood Pile
first thing...
GaryG in MD
is to cut the pith out of them (that's a technical term) quickly before they start cracking. Seal them. Put them in a cool area. Let them breathe enough to prevent mold but not so much they dry out too quickly. Have fun! ...GG
Re: New Wood Pile
Re: New Wood Pile
Mike Potts
Allan, I had a similar problem, Large piece of wood, only a Jet 1642 to turn it on.
I Split in half through the pith.
then cut 14" bowl blank from the outside, I took the remainder and split it Quarters
I was the able to turn a salad bowl and 4 serving bowls, kind of a set
Just one idea.
Safe turning
Mike
Re: New Wood Pile
Re: New Wood Pile
Ron Bauer
In addition to all the other good advice I would take one half of a smaller block and put it on its' end on the ground in a warm wet place to possibly start a spalt. Keep it moist, keep organic matter on and around it, turn it over after a month or so, give it another month..who knows. Just my 2 cents. But you do need to do something soon. Ron.
Re: New Wood Pile
Allan W
Re: New Wood Pile
Allan W
I finally got the chain saw running this week, so I guess I better get busy over the next couple of days. I am thinking of maybe cutting off a couple of slabs from the middle of the larger pieces for platters and then make the rest into bowls. Thanks for all the advice.
Re: New Wood Pile
Re: New Wood Pile
Bill Boehme
Make sure that the slabs are well clear of the pith. I think that I would stay at least three inches from the pith for a platter. It's better to have a slightly smaller platter that is stable than it is to have a big one that cracks or moves a lot.
Re: New Wood Pile
That's great use of wood, Mike!
Re: New Wood Pile
Re: New Wood Pile
Bill Boehme
I am so envious of that FBE.
Re: New Wood Pile
Allan W
Re: New Wood Pile
Allan W
Thanks for the pictures. Tomorrow I plan on firing up the chain saw if it isn't raining and at least get the two large pieces cut up and sealed.
Re: New Wood Pile
Re: New Wood Pile
Lloyd in Mississauga
You likely have the wood processed by now, but something to try and remember for next time...
You should see if you can get the pieces cut 3-4 inches longer than they are wide so that if you do not get a chance to get them processed and sealed, that the end cracks can be cut off and you still have close to a full sized blank. If the blanks start out just as long or shorter than they are wide, then you may not be able to use it for as large a finished piece as you might think.
Re: New Wood Pile
Re: New Wood Pile
phillip Medghalchi
Allan, you can always cut them to a size like large flat rate box and share them with your friends and exchange with their wood that you can not find in your area. I have lots of fun doing that and get a chance to try out the woods that are not local to mine. a 12.5 X 12.5 X 5.5, still a decent size to turn something nice out of them.
Re: New Wood Pile
Allan W
Re: New Wood Pile
Allan W
Thanks for the idea. I got one cut up this morning and should have about 12 pieces sealed this evening. The second large one still needs to be processed. Found out my Ryobi chain saw's bar flexes quite a bit when I am cutting large pieces. It is not as solid as my dad's old McCullough chain saw from the 1950's.
Re: New Wood Pile
Re: New Wood Pile
phillip Medghalchi
I am willing to swap with you if you are ready? just PM me.
