REAL MILK PAINT
Posting Pics
Posting Pics
Posting Pics
Roger hink
Could not get the box to pull pics from my computer, only from internet. I am registered and have a profile. I tried to enter a profile and message said to edit existing profile instead. Any ideas what I'm doing wrong?
Re: Posting Pics
Re: Posting Pics
Josh Bowman
Roger,
Above the box I'm typing in is a "Choose File" button. Select it. It should access your computer. Navigate to the less than 100 kb picture you want to upload. Select it and the little box will say something like "be patient the file is being uploaded". The below picture appeared in the box I'm tying in as a bunch of words and symbols. This image was only 28 kb in size. Hope this helps.
Josh
Re: Posting Pics
Re: Posting Pics
Bill Boehme
I had the same problem a few days ago. I think that it was caused by either not posting in a long time or maybe it was because I have since got a new computer. Whatever the cause, my name was recognized and I had a profile, but when I posted, there was no button above the text box that allowed me to upload images from my computer. The solution was pretty simple. Go to the index page and click on My Profile. Verify that your profile shows that you have a password. If not, you will need to either apply for a new password (very simple to do) or track down your password if you still have the original email that assigned a password to you. Make sure that the Save Password button is selected (unless you like to type it every time that you post) and finally click the Save Profile button. You can also make any other changes you wish while editing your profile. Even if you do not need to make any changes, it appears that clicking the Save Profile button is sufficient to get things working correctly again.
Re: Posting Pics
Re: Posting Pics
William Duffield
On the page that describes how to create a profile, there is this statment:
"The username ("Your Name") must be exactly the same as the one you registered initially."
The problem may be as simple as a typographical error when you filled in Your Name on the new post. For example, an extra space, or the capitalization, will confuse the bulletin board software. User names are case sensitive.
Once you get it working, it is easier to use your WoodCentral cookies to automatically fill in your name and email address on the Reply form.
Re: Posting Pics
Re: Posting Pics
Don Evans
I just went through this also Roger because I deleted all my cookies plus other temp files using Registry Mechanic.
If you see your profile is correct then u must go to (at top of page where you see all messages posted) and click on "Set Preferences" do what is need there and you have to do this on EVERY forum on this site you want to use.
Once that is done, when post a message and there should be a box ABOVE the text area u type your message that has Upload embedded file: then to right of it is Browse button, press that button and find the pix on your computer and double click on it.
Thats it should work:
Your problem is probably the set preference area, that is where mine was.
Thx to Ellis who told me this and got me working again.
Don
Re: Posting Pics
Re: Posting Pics
Roger hink
Thanks for the responses. I understand now the process and sequence of tasks. However I've evidently doubled up on user name or profile or something else. I couldn't even get an email response when trying to change my password.
Maybe if the administrator or someone could delete me from the system I could start over.
Re: Posting Pics
Profile name is the key
Roger, your profile username is "Roger in MO" not "Roger hink". Your cookie thinks you are Roger hink masquerading with Roger in MO's email address. Go to Set Preferences, change the username to Roger in MO and hit the save button. This willl reset your cookie for that board and you will be recognized.
Remember that photos uploaded from your computer must be <100Kb.
Let me know if you have any further trouble.
Ellis Walentine, host
