Party Time -Big chip & dip bowl
Roger Chandler
Party Time! - Big Chip & Dip Bowl!
This has just a little more finish work to be done on it, but that will have to come in a day or so after the Mahoney's Walnut oil is cured out a bit.
This is ambrosia maple..........just a hair under 18 inches wide and 4.5" to the top of the inner bowl rim. Flared out rim on the chip bowl and on the dip bowl for symmetry. This one required soooooooo much sanding........! Several hand and power sanding sequences and then a full sequence of wet sanding with the walnut oil to bring it to this state.......tear out on the punky areas was not fun.........but I used shellac and all other tricks in my arsenal, but finally got it about right............except now that it is dry, I see something in the very center of the dip bowl and area that did not show up when wet..........it will get a little touch up, for sure!
I made this one deep enough to pile the chip and dip onto it.........after all, if you're going to have a party, do it big! I kinda like the curl and the ambrosia features........notice the limb pocket in the bottom as well.....lots of character on this! I purposefully made a wide base for its stability...........it looks better in person than the pics show IMO........I think it will make a nice center piece for a table setting on party day!
