Oil drying times in the hotter/humid weather?
steven antonucci
three four five days? A week?
Never?
AAAAARGGGGGHHHHH!
S
steven antonucci
Never?
AAAAARGGGGGHHHHH!
S
Re: Oil drying times in the hotter/humid weather?
mjonesrdg
Oil finishes are oxidizing finishes (as opposed to evaporative or reactive) and the level of oxygen in hot or humid conditions ought not vary enough to have a very big influence on drying times. Look for some other variable if you are having trouble with a finish that worked well before.
r payne
In my experience (boiled and raw linseed oil), it cures faster in hot weather and slower in humid weather. It makes sense that it will react faster in hot weather (it is a chemical reaction), I don't have a reason for it to be slower in humid weather.
ron
Many variables...
GaryG in MD
First, it depends on what kind of oil.
Second, it depends on the age of the oil and how it's been stored.
Third, hot and dry seems to be better than cold and wet.
Probably more too... ...GG
Bill Boehme
There are all sorts of oils. Most types we use cure which isn't exactly the same thing as drying. If you are wanting to apply a film finish, I wouldn't count on hot weather speeding up the process. It might, but how much? No way to say for certain. Of course any type of mineral oil never cures (except maybe in geological time). Seed and nut oils cure in varying amounts of time. Linseed oil cures fairly fast because of metallic catalysts. I don't put anything over an oil finish except for occasionally using wax. The SNIFF test is always a good indicator -- just sniff the wood and if you can smell the oil then it hasn't completely cured. This test also works on varnish, lacquer, and shellac.
