Sometimes you just have to see if you can do something. In this case I had a large slab from a red oak burl (picture posted earlier). It was the piece just under the cap. The inboard limit on my lathe is 24" and I had not turned anything quite that large before. This bowl ended up at 23" dia by ~3 1/2" deep. I was only able to get one cone out of it because it was so shallow.
A couple lessons learned were:
1. Glue blocks work just fine on a piece this large.
2. There is a lot of vibration near the rim even when advancing in ~1" increments.
3. Sharp tools minimimize the vibration.
4. Don't stop once you start or it will look like a pringle potato chip when it is done. (It kinda does anyway!!)
I don't know what I am going to do with it now. I do like a large bowl of cheerios in the morning. Hmmmmh.
Personally, that is great bowl to set on the coffee table with wrapped hard candy in it.
I have one I did for that purpose and it gets a lot of comments from company.
I keep Hersey Nuggets in it, then consume some after ever meal. I'm not suppose to have sugar but you only live once, right. Moderation is the key. Are 10 of those nuggets moderate?
