Camera question -john Lucas
Darrin hill
Hey.. I dropped my 70-200 nikkor.. Lens shade cracked.. Tried ca to fix but tis too brittle for the plastic.. Any idea on a glue for a rigid plastic lens shade?
Darrin hill
Re: Camera question -john Lucas
phillip Medghalchi
find an industrial glue supplier in your area and look for CA glue that is marked RP5 which stands for Rubber and plastic or go to your big buck store and look for the Locktite brand which is a super glue for plastic. it will say it on the package. I try to get the name of the company for you that has that kind of CA glue I mentioned above (ok, went and got it for you). I hope I didn't throw away the gelled up bottle. they name of the company is Adhesive Systems and this bottle has the label RP5, their we b site address is: WWW.instantca.com
I f you do get it make sure that you store it in the Frige. the darn thing gels up too fast if you live in a hot climate. But, in most cases it's a lost cause because those plastics are hard to glue back together and expecting them to have the same integrity (strength and breakable) .
I never had that much luck after I glued the plastics together ( like plastic tool handles or stuff like that, something about the way they mold them). Good luck
Bill Boehme
Once upon a time many moons ago, Testors, the company that makes model airplane paint also made a solvent that was used to weld the plastic pieces together. It was far better than glue because it didn't involve using something that was weaker than the plastic itself. After it evaporated, the result was one solid piece of plastic. I haven't been able to find it for years, but you might check with a hobby shop if you have one in your area. Other than that, you might try gently applying acetone or lacquer thinner with an artists brush to the edges of the plastic to see if they will work. MEK worked with most plastics, but it is no longer available. Berryman B-12 also is effective, but I don't know if it can be founds either. Any kind of glue isn't going to be nearly as effective as a solvent. Have you considered the ultimate redneck solution ... duct tape? It now comes in all sorts of designer colors.
I can tell you from many years of experience.....
JamieDonaldson
... that you will be better served to just buy a new lens hood. There are so many different compositions of plastic in camera gear these days that finding the correct solvent will be more hassle than necessary, and the repair not likely to survive for long in use. Since most hoods reverse and bayonet onto the front of the lens the repair will not often be serviceable.
Darrin I fixed several at work by epoxying metal to the broken part. You have to scratch the plastic to form a mechanical bond. Use a little imagination to find or shape the piece of metal. I've use everything from coat hanger wire the I flattened to brass shim stock.
yea it's ugly but I was up there yesterday and the new photographer was still using that lens and lens hood. that's about 3 years ago that I repaired it.
Re: I can tell you from many years of experience..
phillip Medghalchi
best put Jamie.
phillip Medghalchi
Darrin, if you go John's way you may want to try using the tin disks that they use for roofing which they nail through it to hold down the felt before the shingles on the roof. I am going to try it on a broken refrigerator handle that I used CA glue on and didn't hold up because of the using pressure on the handle. the disk hardly has any thickness, maybe about 1/128" which will not take up too much thickness in repairing and you can probably get away with it. I am still going with Jamie's recommendation. It may not hold up over time.
The other idea is that you can find those plastic rods at your palstic supplier and turn one out of that, it may work.
Bill Boehme
Lens hoods are generally overpriced, but I agree with Jamie. Just suck it up and pay the money so that Nikon will be able to report record profits this quarter. I know that woodturners are known for being close to their money, but some of the suggested solutions embarrass even me. And I'm one of those whose billfold squeaks when I pry it open.
I believe that there some aftermarket lens hoods, but I don't have any experience with them.
Some other overpriced things are sharpening jigs, tool handles, chuck jaws, signature tools, and a bunch of other gizmos and doo-dads, but I and other turners line up at symposiums to buy these things.
