Finishing Qsn.
phillip Medghalchi
Bellow, you will see a pic. of a bowl of a red bud wood. Please notice that it is not completely finished because I wanted to apply finish to it and then reverse chuck it after. So, you replies would help with the problem at hands.
I just bought EEE Shellawax friction polish and note that it's the
Shellawax Cream that should be used for large turned pieces like bowls as the mnfr. suggests. This is not the first time this problem happened to me on my pieces. I had this problem with other finishes as well.
Here is what I wanted to do, as you can notice i wanted to leave some of the crevices and the valleys that occurs around the knots and the pith intact to preserve the natural beauty which is offered by the wood instead of completely filling it with saw dust and concealing it. I have filled some of the holes and crevices as much as I could to get a better even surface on some of the voids. As it's noticed I get this cloudiness of the wax built up in the crevices and no matter how I try to get in there and polish it they are still there and take away form the beauty of the design and the features int he wood.
How can I avoid this problem or how would you apply wax or other finishes as for not getting those cloudiness and still be able to show case the features of the wood in your design?
Any help is greatly appreciated. I will post the final finished pic. when all is done.
In bellow pic. the no. 1 represents a knot that I filled with saw dust to give it better presentation and no. 2 is the crevices around knot or a branch that happened it the wood, and I filled as much as i could and wanted to showcase that natural indentation of the crevice and you see that it got cloudy.
I called the Craft supply from whom I bought the wax from and asked them for help which they said I should apply mineral spirits to get the was off and then try to reapply it in a very thin sparingly fashion to the wood and build it back up (I did get the fine lines when it was applied). I forgot to mention that the instruction sheet they sent was for the Shellawax liquid (which requires a thick coat) and I mistakenly applied the cream too thick originally and then tried to friction it which caused the haziness on the wood.
However, I like to know how to correct this and what to do in the future?
