overwhelmed with little stuff to do
I've reached a point where it's hard to go into the shop and turn. I have so many little things that need done both in the shop and around the house. It seems like every room I go into has something that needs attention.
Worked on my cheap plastic sandpaper storage cabinet that flexes and makes the drawers drop last night. Hopefully have that problem solved so I can actually get my sandpaper with out cussing. Working on my bandsaw this morning. I ordered a new switch and put it in and it's still not working. not 100% sure I got all the wires back correctly, or there is another problem I haven't found yet.
Got new flooring for the kitchen and baths that I have to put in sometime in the next 2 or 3 weeks. Got to paint the upstairs bathroom and the kitchen cabinets. Then have to replace the front porch railing and decide what to do to make the area under the front porch look better. Have to redu both the front and back sidewalks and spray grass killer on my driveway to try and reclaim it.
The list just keeps going on and on it seems. I still have 3 Oak bowls to turn sometime shortly and those led to designing a curtain to go around the lathe so I don't get those caustic shavings on all of my other power tools.
I do have a demo Wednesday night but that's the last one for a while so maybe I'll have time to get some of the work done around the house.
OH yea, promised the new editor an article on bending wood. I've actually got that and the projects that go with it started so at least I'm doing something.
Re: overwhelmed with little stuff to do
Allan W
Allan W
On your band saw, check to see if has a starting capacitor. I had to replace mine last year. The saw would not start up with out my help getting the belt started. Checked with my son who is an electrician and he suggested a new capacitor. Replaced and now it works fine.
Dick Hines
Dick Hines
See all the free time you have when you retire?
Just think of how busy you would be if you were still doing 40 hours+ every week?
I have been retired for almost 5 years and still have tons of things hanging over my head.
phillip Medghalchi
John, they feel that way because now you don't have to go and punch in. I can relate to it. I think if you can take few moments and make a list of the things that you have to do and then reorganize them by the room or the categories, then com back and reorganize then by the priorities of importance, then you can get them done. I think one of the things that happens here is that you get overwhelmed is because you think they have to be done or finished in one day. if you just take them in small chunks and spend two hours a day on them then you can get them done one after the other. I think when you let them stay in the memories then you get over whelmed by them rather than putting them down on the paper and get hem out of your head and just pick one at a time.
Good luck, Just remember that It took God to create earth in 7 days ( at least that's whet they say) so it will not take you one day to do all those which you listed.
Phillip I am sort of categorizing them. Then just whittle away but it sure seems like a big list. I did finish a hand mirror I started last week and got the one that I turned for my demo in the class sanded and handle glued on. Will probably get some finish on it later today.
I'm still waiting for the bandsaw people to call back. I replaced what I thought was bad switch, then found out it has a seperate release coil (it is a magnetic switch but the release coil doesn't come as part of the switch). Anyway got everything wired back up and now the coil humm's but the switch never actuates.
Going to go to the hardware shortly to buy drywall mud so I can patch the cracks and bad places in the upstairs bathroom. Going to get that painted this weekend.
Have to go in for a Prostate biopsy and they told me I couldn't do anything for 2 days afterwords so Thursday and friday will be watching movies and maybe working on my article a little.
phillip Medghalchi
John, the problem on the Band saw is not any of those you mentioned it's inside the motor and I forgot the name of it, I an call the guy who fixed mine and see what it was and get back to you. It's inside the motor and it needs to be replaced. If you want call me and I try to get it for you. I am sending you an email with my ph#.
Jesper, Denmark
Jesper, Denmark
John, don't sweat the prostate biopsy. It may be a bit uncomfortable during the procedure, but you will be OK after.
I hope the results turn out in your favor.
Ron Pemberton
John, I have suffered thru 3 of those. After each I was back in the shop that day. If the Good Lord thought that little organ was so important why didn't He put it in a more user friendly place?
Don in Central Illinois
I feel your pain. I spent yesterday and today tearing out the kitchen floor so I can put tile down later. Also, have to do sone major leveling as part of the kitchen was an enclosed porch. Then install a door at my daughters and then start painting the house. Glad I'm retured.
Just as my Dad told me would happen, ......
JamieDonaldson
... retirement results in 3 full time jobs that don't pay! :b
you made me laugh- thanks
After a colonoscopy, digital exam of prostate, Ultra sound of prostate and now this, I think my rear end has had it's 15 minutes of fame.
Harry Robinette
Re: Just as my Dad told me would happen, ......
Harry Robinette
Your dad was a wise man. Mine told me when you retire they take 12 hours out of your day so your always behind.
He also keep telling me that his golden years had turned to lead.
Bill Boehme
Do you have lockout switches on your bandsaw? Also, don't forget to rotate the mushroom stop switch.
If the motor hums but doesn't turn then it could be one of two things: start capacitor or centrifugal switch.
If you will do like me and store the sandpaper on the floor then you will reduce one cause of cussing until it gets covered up with too much other stuff.
