storing walnut oil
storing walnut oil
storing walnut oil
GaryG in MD
I've read that walnut oil (in general) goes rancid pretty quickly and has to be stored in the frig.
Is this true of the walnut oils sold as finishes, such as Mahoney's? ...GG
Re: storing walnut oil
Don in Central Illinois
I have some walnut oil purchased at Kroger close to a year ago and it hasn't turned rancid.
DKWalser
Gary - Mahoney's walnut oil is heat treated, which I believe prevents it from going rancid and helps the finish to harden more quickly. I believe, but do not recall for sure, that the same is true of the walnut oil from Doctor's Woodshop. The walnut oil in most supermarkets is raw. Still, I'm told even the raw walnut oil is less prone to going rancid than are other nut oils.
HTH.
I haven't stored Mahoney's oil anywhere other than my finishing cabinet and it's still good after a year or more. It is heat treated or some technique when it's made but my understanding is this is to change it to remove the nut alergen properties.
I have used regular walnut oil to heat treat tools for years and i don't believe it goes rancid. That jug has been around for several years. I use it instead of regular oil because it has a higher flash point and is less likely to cause a fire when I dip the hot steel into it.
Brad Vietje
NO  Lasts for Years
Brad Vietje
I have Mahoney's Utility Finish some I got from my dad when he died 10 years ago, so it must now be about 11 years old. Found it and started using it late last summer, and I still have some. Still clear, still liquid, still works fine.
Store it away from sunlight, though -- UV light will accelerate the polymerization of the oil.
Safe spinning,
Brad Vietje
Newbury, VT
Thanks, all
GaryG in MD
Sounds like I'm going to have to get some of that.
Thanks for the tip, David. ...GG
Re: storing walnut oil *LINK*
William Duffield
I think you will want to read the linked post (and even the responses) on rancidity of vegetable oils, over on the Messages forum. It will answer all your questions. I think the results of the discussion have been permanently archived in the Wood Central Articles, as well.
Cutting Board Finishes
good info, thanks!
Thanks!
David Walser
Very interesting and useful comment thread. Thank you for linking to it.
Something I'd add is that not all walnut oils are equal. Those sold for use as woodworking finishes generally are heat treated. This decreases the time it takes for the finish to cure. (This is why linseed oil was often "boiled". These days, linseed oil sold as boiled typically has NOT been heat treated. Instead, chemical dryers are added to the oil to make it cure more quickly than untreated raw linseed oil.) Some of the walnut oils sold in supermarkets have been heat treated, but most are raw. Raw walnut oil will still cure, it will simply take much longer.
Some of the supermarket oils have agents added to them to prevent the oils from curing -- adding to the oil's shelf life. These oils might work as a finish on butcher blocks and cutting boards, but I think its best to avoid them for anything but a nice vinaigrette.
Heat treated, raw, and chemically treated walnut oils will not act the same. You need to know which you have so you can know what to expect from the oil.
Re: Thanks!
William Duffield
I've had pretty good results with Loriva, before I started using Mahoney's Utility /Finish. You have to read the labels, because some grocery store "walnut oils" have a lot of other vegetable oils added, because they're a lot cheaper. They contain about as much walnut as snapper soup has snapping turtle.
Bill Boehme
I don't think that it ever goes rancid.
I don't know what is in Mahoney's Walnut Oil Finish so I have used for years is La Tourangelle Roasted Walnut Oil (see link below). It is pure Walnut oil from the nuts that have been roasted and then pressed to extract the oil. It has no expiration or use by date. They recommend refrigerating after the can has been opened since there are no preservatives to kill bacteria that might get into the can one the seal has been broken. I have one can that has been in the fridge for about three years. I use it to oil woodturnings occasionally and also to make salad dressing. I made a balsamic vinaigrette dressing today using the walnut oil. Tastes great.
Joe Ruminski says that he also uses the grocery store gourmet walnut oil since he knows what he is getting -- nothing but pure roasted walnut oil.
Good info, Bill.  Thanks
phillip Medghalchi
Bill, I went on that link and their site and this is what they published, so I am not sure how you got 3 yrs in the frig. out of this and what about the nut allergies if you put this on a salad bowl ad sell it then soem one in the consumer's house hold has nut allergies?
Now, I have had trouble with Mahoney's walnut oil and even though I called him I did not get much of help about the problem I had.
GaryG in MD
All finishes are food safe when cured. ...GG
Bill Boehme
They say that it has a shelf life of two years unopened, but my can doesn't have a date on it nor does the new unopened can that I bought a few months ago. I imagine that they are saying that with respect to flavor because like everything else, the flavor is better if it is newer. A lot of canned vegetables never carried expiration dates, but I think that they are required to do so now. A lot of them say for best flavor use by ... The web site also says that once opened use within six months, but again I think that that would be assuming worst case conditions. I never take it out of the refrigerator longer than necessary and promptly cap it and put it back in the fridge. I don't leave it sitting on the counter with the lid off for hours. Anyway, I am still alive today, after making a walnut vinaigrette dressing yesterday so it can't be too bad. :D
I think that Gary said nut allergies applies to eating the product and not using it to oil wood. I think that the nut allergy warning is there because this is sold as food ... a salad oil. I imagine that Mahoney's Oil might need a few additional warnings if it were sold in the grocery store as a salad oil. With any kind of nut or byproduct that you buy, there is always the possibility of cross contamination from other nuts just because all of the harvesting, handling, and processing equipment is far too expensive to just sit idly by waiting to only be used for one specific crop. So it would not be too surprising if a stray goober found its way into a batch of pecans or walnuts or pistachios.
Besides, it's up to each of us to decide what type of finish to use. If the thought of walnut oil give you heartburn then don't use it. I suspect that Mahoney's Oil isn't any less subject to contamination from a stray peanut. Does the cured oil matter? Are there any allergies to flax seed or tung nuts? Possibly, but "they" say that cured linseed oil and tung oil are not harmful.
I've never made a salad bowl and probably never will so that has not made it onto my list of things that I need to worry about. In fact, the appeal of making bowls is at the bottom of my list of why I like woodturning -- even lower than making bottle stoppers (apologies to Ruth Niles). Despite that, I still make them because everybody wants them -- Empty Bowls Project, relatives, etc., but they aren't functional bowls. Oh, BTW, I make a few bottle stoppers as well for friends and relatives who insist. So far, I haven't sold anything because I am already retired ... for good and not interested in a below poverty level full time job.
phillip Medghalchi
Bill the expiration thingy is more of a bureaucracy than anything else. Because if they say store food in the undergrounds shelter for the disaster in the areas that prone to storm and natural disaster, then how often you have to go through your stock and throw away your food. On the other hands I think the main problem is the introduction of the air to the food that makes it go bad. So, in most cases i think is the media and the general phobia of bacteria are the culprit not the allergies.
Bill Boehme
Nut allergies are a real serious issue for anybody that has an allergy to them and are the most common type of allergy in children. Peanut allergy affects about 1.3% of the population. Tree nut allergies are less common. Reactions can range from mild to anaphylaxis and people with severe reactions have to carry Epi-Pens all the time. From what I understand, it is somewhat like poison ivy in that the immune system over reacts to a protein in the nut.
