Hannes "Quick Coring" Tool
Bob Aumock
Has anyone had the opportunity to use the Johannes Michelson "Quick Coring " tool ? Looking for the Pros & Cons
Thanks,
Bob A
Re: Hannes "Quick Coring" Tool
Donna Banfield
I have one of the original coring tools he made. I don't core with it, but it is a great parting tool when I need to go in deep, which means hanging off the tool rest quite a ways. Instead of just your hand and forearm to keep the tool from dipping too low, the weight of your entire body is controlling the tool. I don't use it very often, but when I do, I'm real glad to have it.
Peter Lamb
I have an older version too and love it. When the McNaughton gives me fits Hannes's tool saves the day.
As Donna says it is the best as a deep parting tool. I can get four blanks from an 11"x4".
The smallest being 4" then 6" then 9". It has a carbide cutter which really does the job.
Well designed and very well made tool.
Maybe I'm confused but it's not really like the curved coring tools for cutting out bowls. It's a straight tool. A well designed tool and it does the job it was designed to do but it will only cut out cones not bowl blanks. Granted they could be shallow bowl bowl blanks. I remember Rude Osolnik had one similar many years ago that he used to cut out cone shaped blanks that he would use for other things. Not putting it down I just don't see how it compares to the McNaughton or Oneway coring tools since it can't cut a curved line.
Peter Lamb
I certainlt agree that it does not. But I still have problems with McNaughton.
Donna Banfield
John, this is a straight tool. Hannes uses it to take the center out of his full size Range Rider Cowboy hats. That core then is used to make his mini and micro-mini cowboy hats.
Before he developed his own line of tools, he used the straight McNaughton blade. His version doesn't use or need the McNaughton tool post/gate. Your entire body replaces what the McNaughton gate does. The end of the tool tucks under your shoulder in the armpit. There's a handle halfway down the shaft underneath and vertical that you hold with one hand, and the other hand rests on the top of the tool. You use your entire body to move, guide and control the tool. If there ever was a tool that applied the woodturner's waltz, this is it.
I used to have the McNaughton coring tools. It was always a white knuckled task for me. Not so with Hannes' quick core. There's a video on YouTube of Hannes using it. It looks like the tool is 'lifting him' but he's actually using his body to control the tool movement.
Because it uses a nano carbide cutter, the tool makes short work of the job. It is used for side grain orientation only. Like I said, not a tool I use very often, but when I do, it's the only tool for that job.
If you're ever in New England, look me up if you want to try it.
Donna I agree it is an excellent tool. I'm not putting it down at all. All I'm saying is it doesn't do the curved cores that most people think of as a bowl coring tool. I'm not a huge fan of the McNaughton system as I'm still fighting it. Did learn some new tricks on my last demo tour however and hopefully before very long will have a chance to try them out and then maybe I will enjoy the coring better. Hey if not I'll just buy one of Johannes tools and do straight line coring when I find it necessary.
Craig Daymon
Was the McNaughton tool called the "Slicer"? I remeber one by that name that was only intended for taking a conical core out, but I don't remember made (or makes) it.
White knuckles
jeff Willaford
I'm not a pro turner and every tool I've used was a white knuckle experience for me.... until I learned to use the tool. Now I don't even think twice. I just pick up the tool that I think would be best for me to use for the project at hand and go. Quite often I reach for my McNaughton center savers not to save wood but to reduce the amount of shavings I have to clean up. I've never seen Hannes quick coring tool but I'm sure I'd use it the same way and it would do a great job for me.
I once saw John Jordan use the handle of a gouge as a hammer. Someone at the demo asked if John thought of every tool as a hammer and he replied "No. I just don't think of my hand as a hammer." I don't think of my body as a replacement for the McNaughton gate and I hope no one every tries to take my center savers away from me. I'd like to think everyone feels that way about one tool or another.
That was part of the Stewart tool.
Bill Boehme
I have watched Johannes use his tool several times at SWAT to remove a conical piece from a full size hat as already mentioned. Of course it was very easy for him to quickly cut out a conical plug. Since there can be a lot of overhang from the tool rest, it can take some effort especially if you get aggressive. I would think that you need to go slow and easy and make sure that the tool is sharp. I have arthritis in my shoulder so I am concerned about doing anything that would irritate it.
