Just back from the sawmill..
ron bauer
I just got back from cutting a red oak burl at a friends sawmill. Here is the burl on the mill. Sorry the picture is so pixolated, my friends wife took the picture and I don't know what the settings were.
Here is the result. The lower left is the cap and has a minor dimension of 22". Lower right is the next below the cap and has a minor dimension of 27".
The other two are the interior slabs and show a lot of ant damage but still have significant solid areas. I can only turn <24" inboard so the chain saw cut on the one slab won't be an issue. Ron.
Re: Just back from the sawmill..
Steven Antonucci
Why did you slab it?
steven antonucci
I probably would have just had them mill it off whole...and then use a chainsaw for blocking it up. Are you making a table top?
Steve
Re: Why did you slab it?
ron bauer
Steve, The prime objective was to get a natural edge blank that would offer a bowl ~8" deep. Unfortunately the throat on the mill is max 0f 26". With the curvature of the burl and the need to grab the log I could only get the cap at 22"dia and 4" deep. In my mind I have more options with a second slab than trying to cut a big cap with a chainsaw. The "good" slab required four cuts on the mill to get it seperated. The other constraint I have is a max swing of 24" (inboard) on my lathe. I considered going outboard but have never done it and am a little cautious (read scared) to try it. The slab will still make a nice large flat bowl/platter. Anyway, I have a hard time selling a 12" bowl let alone a 22+incher. I considered a table until I realized that the woodsman was over zealous and cut in to the burl. R.
