THE WOODRAT IS BACK!
tool handle
tool handle
tool handle
darrin hill
making a few tool handles for some big skews.. 1 1/2 inches….
never made a tool handle before…
is there a proper weight something or other for the handle vs the metal tool or do it till it feels right?
read somewhere that if u balance the finished tool on your finger around the join area then you've achieved a good weight …or should i put some shot in the back end so when turning the weight isn't all on the metal end?
Re: tool handle
Re: tool handle
Chuck Engstrom
Hi Darrin -- I like a bit of weight in the handles, so I'll suggest that you drill out the back end of them while you are making them. I have generally used a 5/8" forstner or drill. Put some lead shot in there, leaving a bit of space for it to slosh around, and seal it with a cork well secured with tape. If you like it, take out the cork and glue in a wood plug for real security. If you don't like it, take out the show and put in a plug but maybe don't glue it in case you change your mind. It's much easier to do all this on the lathe before you have a blade at the other end.
Good luck with it! -- Chuck
Re: tool handle
Rob Wallace
Re: tool handle
Rob Wallace
Another tip....
..... if you are adding lead/steel shot to a wooden handle and want to make it weight adjustable, drill out the inside part of the handle you need to add the shot to, boring into the handle end. Then epoxy a threaded insert (brass or steel) into the opening (use a wooden plug, if necessary) and seal the opening with an appropriately-sized threaded machine screw (I recommend 3/8"-16; you can counter sink the Insert/screw a bit to sit flush with the handle end). Simply taking out a machine screw held by the threaded insert makes adjusting the amount of shot very easily done. This has worked well for me; sorry no pix available from here....
Another handle-making 'rule of thumb' is that the handle length should be about 5 times the expected overhang of the cutting edge of the tool (i.e. a 15" handle for an expected overhang of 3"). Since a skew is a spindle tool, the amount of overhang will be much less than a gouge or scraper, so the handle can be correspondingly shorter. Also, make sure your handles are sized comfortably for your hand (diameter). There is a tendency to make handles too thin, which might cause fatigue or cramping - don't ask me how I know that.... Also, make sure your ferrule fits well; epoxy it on if necessary.
Good luck with your handle project! Turn safely!
Rob
Re: tool handle
Steven Antonucci
No overhang with a skew...handle can be any size
steven antonucci
I make mine out of whatever I have laying around. I used them like hammers, so I don't go too crazy with finish.
In general, my skews are 2:3 for steel to handle ratio. It could easily be 1:1.
Steve
Re: tool handle
Re: tool handle
David Walser
Darrin,
The proper weight of a handle is what feels good to you. Some people like their tools to be heavy, others don't. It's personal preference.
You might find that your preference depends on the type of tool and what you'll be doing with it. For example, roughing out a bowl can produce a lot of vibration. Lead shot is good at dampening that vibration. So, you might like a handle weighted with shot on bowl gauges. On the other hand, a skew is generally used on more delicate cuts -- the final cut on a fine taper or turning a bead. In such an application, you might not find extra inertia in the handle all that attractive! Think about how you'll be using the tool and whether extra weight would be desirable or not.
Personally, I don't want any extra weight in my skew handles, while I like extra weight in my bowl gouges. YMMV
Re: tool handle
Re: No overhang with a skew...handle can be any si
All of my handles are approximately 16" long because I like to let the too ride on my hip. The only ones longer are the big bowl gouges for roughing. I also don't like weight in my handles. Although it does absorb some vibration by the end of long session your worn out from just holding the tool. For my big roughing gouges I use weight. All other I don't.
the other thing I do is to bore the hole for the tool first. Then I mount the blank between centers using this hole. That guarantees you get the tool centered. Like Steve I don't usually spend a lot of time on tool handles. It's just a tool for me, not a show piece.
Re: tool handle
Re: tool handle
robo hippy
I have 2 lead shot filled handles, and those tools are now on a shelf under my bench collecting dust. For a long day's turning, that is just too much weight to horse around. Most of the time vibration comes from trying to hang out too far off the rest.
For a skew, which has a square or rectangular tang, I make a 3 piece sandwich handle. The center/meat and cheese part is the exact thickness or maybe 1/64th inch thicker than the skew tang. I cut a mortice or slot the same size as the tang. Then I add two pieces of bread on the outside and glue it up. Turn it round, put the ferrule on the handle, then set the skew into the handle. I generally have to pound them in by inserting the skew, then hitting the handle end on the bench, directly over a leg so there is no bounce.
robo hippy
Re: tool handle
Re: On the topic of tool handle
ron bauer
Comfort and confidence while turning makes for a nice afternoon. To that end I started making my tool handles in a tri-lobe style. They are very comfortable in the hand and give a feel of confidence. I start with 2" stock, cut the sides at 30 deg on a bandsaw (way to dangerous on a table saw), move the fence and knock off the corners. Sand if desired. I install the tool with about a 20 degree rotation to the left (I am right handed) which presents the tool upright when held comfortably. Anyway, I am not looking for converts, just adding my two cents to the discussion.
Length and weight are at your discretion. Ron.
Re: tool handle
Brad Vietje
Nice... and these won't roll off the bench!
