I think I would need a spindle of at least 2" and probably without a morse taper so it would be stronger. Lathe would need to weigh in at a ton or more. My friend Joe Looper had the lathe which had a 54" swing and can't even guess at the weight. He had a 5 horse motor on his.
... on a Highlander lathe from Scotland during our American Woodworker Shows in 1997. I can't recall exactly, but I'd say the swing was around 10' -- actually, I think they were prepared to outfit it with a riser kit should you need additional capacity. Our bowl finished out at 7' - 9 1/2" OD. The ring tools we used were 7' long with shanks around 1 1/4" as I recall, maybe heavier. We started the blank at about 3 rpm and got it up to maybe 30 at the end of the process.
I'd definitely say that a Morse taper wouldn't be necessary if you need a lathe that big. We used a 24" faceplate on the headstock and a 16" faceplate on the tailstock.
