General 26020 Tool Rest Clamp
Tom Henderson, Gulf Breeze Fl
The eccentric bar in my circa 2001 General lathe came completely out from the banjo today. After looking at the bar, I found it has a groove which centers under a grub screw in the base of the banjo. In that groove I found a short (1/8th inch long) cylindrical rod which fell out.
The small scale diagram of the lathe in the manual is not very helpful.
I am assuming that the short cylindrical rod that fell out is the remains of a longer piece which the grub screw forced into place in the groove to hold the bar in place.
Anybody else have this lathe? I am calling General's customer service also.
Re: General 26020 Tool Rest Clamp
Bill Howatt
I just took mine apart. The 1/8" piece is actually part of the grub screw so yours has broken off the screw. I think the idea is that the shoulder made by the smaller diameter 1/8 piece allows the screw to be tightened down and the smooth 1/8 piece is then in the groove keeping the shaft in place.
You probably could make one with a suitable length grub screw or even a piece of threaded shaft from a machine screw and some grinding/filing. I think grub screws are hard material so they can normally bite into shafts but that isn't the case here.
Bill
Tom I don't think the rod actually needs to be part of the grub screw. I see this all the time in machines with either a ball or a rod being pushed by the grub screw either into a divot or into a groove for a moving part. I would just assemble it with the rod in the groove.
I do wonder why it fell out however and would look at other possibilities for that.
It fell out when I disassembled it. Bill says it is part of the grub screw which has broken off.
I have called General and after some confusion (it would help if I spoke French) they are looking into it and will call me back.
I have tried placing the broken off piece back in the groove and tightening the screw, but that doesn't hold the eccentric bar in place.
Thanks to both of you for the quick responses.
