Summer closing in...
Steven Antonucci
steven antonucci
As I sit in my sunroom (home office), I've been noticing that it's getting a little toasty over the past couple of weeks. Great in the winter, less so as summer approaches. I have recorded 104 degrees or more in the room in the past, so I know it won't be long.
Last night, I noticed that the show was a little bit warm because I was wearing jeans. I could wear shorts, but that just means I will itch from the 10,000 mosquito bites I would get. Pick your poison. Pretty soon, it will be shorts and DEET...
What do you guys do as the weather makes working in the shop a little less fun? If you have AC, I don't wanna know :b I did a little cleaning last weekend, and maybe some spoon carving in a beach chair, but life slows down come July...
Steve
Re: Summer closing in...
I just open the doors to the shop and turn on a fan. when it gets really unbearable, meaning high nineties with lots of humidity I have a small airconditioner I turn on, but all it does is knock the edge off because it's sized for about an 8x8 room and I'm cooling a 24x24 room. The fans blowing directly on you help tremendously. Keeps the mosquitoes off you as well.
Stuart Johnson
I'm good if I can get started before it hits 90 in the shop. Depending on the time I'll open the east door and set fans blowing out plus a couple blowing on me. Sanding with a dust mask gets put on hold until I can get out early in the morning. All in all the cold (below 60) bothers me much more than 100.
Steven Antonucci
60 is shorts weather LOL
My shop walls are part of the house ......
JamieDonaldson
...foundation and are about 8' underground, so the earth acts like a heat sink that helps moderate my shop temps. I can't tolerate turning in shorts because the chips just fill my shoes, so I always have to wear long pants. Besides, my white bony legs are not suitable for public viewing!
Re: My shop walls are part of the house ......
Bernie Rose
My shop is attached to the house, and also has 2X6 studs. When it gets too warm I leave the door open to vent some of the "Cold" from the house to the shop. It also pays that I put in small windows and few of them. To keep the dust from the house I have a small window exhaust fan to vent the dust and heat from the shop.
Brad Vietje
Re: Summer closing in... *LINK*
Brad Vietje
Steve,
I currently turn in a small section of a 42' x 60' horse/sheep barn -- no livestock anymore, but that's what it was built for. Unbearably cold in Winter, but generally pretty reasonable in Summer. I open 12'x12' garage doors at either end when a breeze is needed. That big roof can get pretty warm (corrugated aluminum w/6 "panes" of translucent fiberglass for light, about 3' x 6' each), but it's a ways up there.
Thermal Performance:
For anyone planning to build or renovate a shop building, my new house might be a great model or at least food for thought. It has walls of straw bales; roof is supported by a traditional (in fact, old and re-used) timber frame, and the straw bale walls wrap around the frame. Bale walls are coated with earthen plaster ~1.5" thick on inside and out, creating a very tight wall system 16" thick with R-value about 45. Passive solar design allows low-angle winter light, but roof overhang prevents sunlight from getting in from mid-Spring to mid-Fall. House is about 1400 sq. ft. with 10' ceilings downstairs and knee walls with sloped ceilings upstairs, so a larger than normal volume for the 30 x 30 footprint.
Bale Wall Before Plastering:
Bale Wall During Plastering (different window):
Bale Wall After Plaster and Milk:
We heat with 2 cords of wood in a climate with roughly 8,000 heating degree days, up to 2-1/4 cords for a colder winter like this past one. When it's 90 degrees out in summer, it tends to be in the mid-70's inside.
Conclusions: Think walls with lots of insulation can keep you warmer in Winter, and cooler in Summer. Straw bale houses are fairly rare, so hiring someone to do the work is difficult and expensive. A quicker and easier "stick-built" route to get high performance walls -- and superior to straw bales if done right -- would be a 11"-12" thick wall system stuffed with dense pack cellulose. Best structure is a Larsen Truss wall with 2x4 and 2x3 framing that can go up very fast and easy, and can be done by any builder once they understand what you want. Dense-pack cellulose will give you a desired level of performance for less than 1/2 the cost of spray foam, though foam has other strengths, and does not need the same thickness to get to the desired performance level. Usually foam can be better for retrofit work (where wall thickness is limited), and dense-pack cellulose is better for places where wall thickness is not so limited.
Hopefully I can spark some good ideas that will keep you warm in winter and cool in summer.
Safe spinning,
Brad Vietje
Newbury, VT
Larsen Truss Wall Systems
