cutting bits
cutting bits
cutting bits
adrien coblentz
For deep hollowing there are square cross-section bits about an inch long and 1/8" on a side that fit into a steel rod which can then be handled. When dropped on the floor the bits have a tendency to break off–which is what happened to mine.
I don't know what these little tungsten carbide bits are called nor where to purchase a replacement and would appreciate guidance. I made assketch, but couldn't figure out how to get it into this message.
Re: cutting bits
Re: cutting bits
Dale Miner
The bits most people use are 3/16" square, and are made of high speed steel (HSS). HSS bits in just about any size can be purchased at several outlets like Enco, MSC, McMaster Carr, Wholesale Tool, etc. The bits come with a standard length of about 2.5" and can be shortened by scoring with the edge of a grinder wheel or dremel cutoff wheel, and then placed in a vice and snapped at the score. I like to snap the bits by using a good sized adjustable wrench and pushing sideways against the notch, some folk like to snap the bits by hitting against the score with a hammer. Which ever method is used, place a rag over the bit and wear safety glasses.
Re: cutting bits
Re: cutting bits
Dale is right. If you have something else tell us what the brand of the tool is and maybe we can help you. I probably have lots of extra HSS in the 3/16 size and would send you a piece if you give me your snail mail address
Re: cutting bits
I'm guessing you are asking about....
The carbide cutters that are interchangeable, but generally can not be sharpened by the end user. Many are round and about 3/16" in diameter and you rotate them to a new shaper section as they get dull and replace them when they are dull and worn out.
There are a number of purveyors here and I don't know all of them. One is Mike Hunter.
You can buy parts or "tools" that include the handle and the bar and cutter. Sometimes you can interchange them with the HHS cutter. There is a learning curve to the cutting action.
Re: cutting bits
Very helpful you guys, Thank You!
Re: cutting bits
Re: cutting bits
steve worcester
TURNINGWOOD.com sells the Hunter insert, but you can use HSS steel cutters sold by the metal working industry like the others have described. If you are snapping cutters, use less protrusion from the tool. And maybe a lighter touch.
