Use for old Colored Pencils
Re: Use for old Colored Pencils
steve worcester
I loved that, just would have used epoxy myself with all those joints
Dan Jechura
dan jechura
I was sent that link from someone else and got me thinking, bowl rims.
Dan J.
Allan W
Allan W
I like that idea. I could see using that to accent small bowls.
Lloyd in Mississauga
They could be used as "veneer" between segments in a feature ring, leaving a colored dot between the segments when turned.
Or they could be cut for the segments themselves on a closed vessel so that you would not see the inside ends.
Matt Overton
Thanks for the idea. I have about 2000 colored pencils from a friends shop that I have been cleaning out.
well I'll have to try turning those. I turned regular pencils with dissastrous results. The graphite bled all over everything if you even remotely got sandpaper near it. He obviously didn't have that problem.
