off center pendants
off center pendants
off center pendants
Finally had time to play in the shop. Linda Ferber and I had some fun discussions about Pendants when I stayed up there. I had this idea for a change in my pendants and wanted to play with it. Think it still needs work. The idea was to have a half circle and then put a full circle in the middle. Getting the sizes right remains a challenge.
The top center is not cut off like the rest and like the way your eye flows better. I'm thinking that maybe the cutoff needs to not be straight. Maybe slopped down toward the center circular detail. Anyway it was fun playing with this idea. I'll be away from the shop for the weekend so may do some more drawing.
Re: off center pendants
Steven Antonucci
Comments
steven antonucci
My eye likes the one on the right the most, top middle the least.
The other two I would probably like more if the "full round" sectiion was concentric with the other circles in the large disk AND it wasn't bisected at the diameter of the smaller element (if that makes sense?)
In addition, I probably look at the pieces vertically...
just some thoughts
S
phillip Medghalchi
John, I admire the designs. For the beginning of the process you did well, I like the middle top and the right one. the bottom middle and the left the idea is Ok, but something doesn't feel right. Maybe if you use sketch up or another design program to do it on the comp. and keep tweaking it until you find something pleasing to you. However, though don't give up on the design, they look good and original. look forward to see what you come up with.
Brad Vietje
Brad Vietje
Nice adaptation, John. I like the right and left examples more than the 2 in the center, and the one on the right would be my #1.
It will be interesting to see how people respond. This stuff is very subjective, but we tend to be guided by physical principles like symmetry and balance, too. It might even matter if the chain or manner of suspension were included -- hung from one point at the top center? from right and left side? from a hole in the wood vs. a hook eye, or an invisible point in the back.....?
These could also work as a brooch or pin, so no dangly thingy visible at all...
Safe spinning,
Brad Vietje
Newbury, VT
I agree
GaryG in MD
I think the suspension points and material will make a huge difference and need to be included. These look like pins the way they are now. ...GG
Re: I agree
John lucas
The original concept was sort of a sun rising. Thus the long horizontal element with the ball. Obviously some thing else needs to be done if I stick with that concept.
