Using a drawbar: AAW Fundamentals video
Alan Zenreich
For anyone interested here's my latest video for the AAW Woodturning Funamentals program.
http://vimeo.com/93999983
Alan Zenreich
Saw it on FB... good job
Excellent initiative.
Geoff Whaling
Great to see these being developed - well done Alan Z.
Thanks, Alan; very practical
Re: Using a drawbar: AAW Fundamentals video
ron bauer
Alan, Like some people I use a drill chuck in the tail stock. How do you use a drawbar in the tailstock? I have had them pull out when using a forstner bit.
Alan Zenreich
Generally one does not use a drawbar in the tailstock. The difficulty is that the typical use of a drill chuck in the tailstock requires that the tailstock's spindle length be varied during the drilling. So there's no fixed length to tighten the drawbar to. Most times it's not much of a problem because the forward pressure is helping to seat the chuck into the tailstock's taper.
It's important to make sure that the chuck's taper length is appropriate to the tailstock's taper... I have had to cut one of my chuck's tapers a bit shorter to fit a small lathe.
In a drill press, there is often a flat that seats into a mating slot at the end of the taper, and this keeps the chuck from twisting... We don't have that slot in a tailstock.
pins or set screws to lock morse taper
We had a discussion about this a while back. You can probably do a search and find it. You can't use a draw bar on tailstocks for drilling because extending the quill changes the length from the back end of the tailstock to the quill, and some tailstocks aren't hollow.
What was suggested was to drill a hole in the side of the tailstock quill and into the drill chuck morse taper. Then insert a pin after inserting the drill chuck. I took it a step further and drilled and tapped a whole and put a set screw in. I ground a flat on drill chuck morse taper and now all i have to do is lock the set screw down on the morse taper flat and it's locked in place. If you do this it's important to clean up all burrs created on the inside of the quill and on the morse taper otherwise it won't hold as good as it did in the beginning.
How does your tail stock spindle grow?
steven antonucci
inquiring minds would like to know? Mine has always been the same length
How much projects changes, but it's never gotten longer? If your quill is hollow (like on a Nova...like you own), you could just thread through the quill to the back of the drill chuck and local against the back of the quill.
If you have a quill that gets bigger, have it teach the headstock how to get bigger too
Re: pins or set screws to lock morse taper
ron bauer
John, Thank you for understanding my point. With large bits it is common to have the taper get pulled out when retracting the drill chuck by turning the tail stock handle. Every time a pepper mill is drilled this problem comes up. I believe your adaptation of a set screw is the only viable solution. Thank you for confirming my thoughts. BTW I have a #2MT finishing reamer that I periodically use to dress the inside of the quill. R.
Re: How does your tail stock spindle grow?
Alan Zenreich
Agreed. It would be possible, though not convenient, to remove the quill, install a drawbar, then reinsert the quill into the tailstock.
I rather like the approach of adding a set screw to the quill, and filing a flat or drilling a hole in the drive taper to accept the screw.
Alan Zenreich
On the Nova tailstock, you can use a conventional drawbar if you only need the quill to extend about 2".
If you need to use the full length of the quill, it would be a simple matter to make a "cork" shaped plug with a through-hole at the threaded end of the quill, and insert a rod and tighten with a bolt. Pretty straightforward.
So the solution depends on the physical configuration of the tailstock.
Of course, this also assumes that the drill chuck has a thread for a drawbar... and also hopefully the chuck itself won't rotate around the Jacobs taper that attaches the chuck to the Morse taper.
Alan Zenreich
Another tricky thing is finding a drill chuck with a Morse taper mandrel with a thread that accepts a drawbar.
Typically these are used on milling machines (the one MT3 item in my video is from a mini-mill I have, and the reason it's not in the mill is because I replaced it with a collet chuck).
I suspect that a threaded mandrel may be available separately, to replace the current mandrel on existing chucks. Then make sure you have the correct type of drift pin to remove the spindle from the chuck...
The set screw approach is sounding better and better...
Radical - a tailstock thread - please
Geoff Whaling
Using a set screw to secure the MT2 taper in the tailstock could actually add to your drilling accuracy woes. It could slightly skew the axis of the MT2 accessory to the tailstock axis or jamb a MT2 in the tailstock quill if the set screw was inadvertently not nipped up securely allowing the MT2 accessory to be rotated with heavy use i.e. large forstner bits. Given the slop/freeplay between the bedways & tailstock on most lathes any axis deviation should not really be an issue.
The original Nova Mercury mini lathes had a tailstock spindle thread that accepted a collet chuck for drilling. Its main selling point was that a jacobs chuck was not required thus give you more lathe bed real estate to use for the workpiece.
I can't see why the tailstock quill could not be modified to feature a thread identical to the headstock to allow the use of a dedicated & much safer ER25/32 collet chuck like Vermecs units. Maybe I should patent that idea ;-)
Re: Radical - a tailstock thread - please
Alan Zenreich
Goeff,
I agree that a collet chuck with a drawbar is an ideal solution.... EXCEPT if you have to change drill bit sizes often (very common with pepper grinder construction).
No good deed goes unpunished.
Geoff Whaling
Alan - no draw bar required if the tailstock is threaded similar to the headstock. Requires a new way of thinking about how to use accessories in the tailstock. Certainly always pros & cons like using MT2 extensions. Forstner bits one you get up in size usually have a standard shaft size so not a great issue. The Vermec ER collet chucks are very versatile with a full range of collets, however practicality & purchase cost, but mostly cost, persuades most users to go to a MT2 Jacobs chuck.
Alan Zenreich
Geoff, I was referring to available MT2 collets with a drawbar thread... not collets that thread onto a spindle that's not present on our lathe's tailstocks.
Alan Zenreich
... and of course, you are correct about the consistency of the shaft size on Forstner bits.
For those who are not familiar with MT2 collets, here's a photo of a set.
And a link to a set on Amazon that has a 3/8-16 drawbar thread. I haven't checked the sizes to see if they would work with my Forstner bit set (most probably a 3/8" shank on each bit).
http://www.amazon.com/Collets-2MT-Set-of-7/dp/B002YPFSEM/ref=sr_1_1
They are also available as individual collets, instead of a set.
at http://littlemachineshop.com/products/product_view.php?ProductID=1749
now all we require is a tailstock thread - please
Geoff Whaling
now all we need is a threaded tailstock quill to be able to use a whole range of existing accessories and to make deep drilling or any drilling far safer for turners.
Just imagine - No more forstner bits with a Jacobs chuck flogging about just waiting to damage an expensive piece of wood or maim a wood turner.
keith tompkins
Just a couple of thoughts...When deep boring, the bit should be withdrawn many times during the boring operation to clear the chips. Otherwise, chips may expand behind the bit,making it difficult,even dangerous to withdraw the bit. In some cases I mount the bit in the headstock, and secure the chuck with a draw bar. (may not apply for some applications) It that case, the stock must be secured to prevent it from rotating.
