speed in turning
Mike Potts
I've been trying to wrap my mind around turning speed. I think I've got it, but wanted to bounce off you guys. When we talk about speed RPM always comes up " What RPM should I turn at?" After thinking about it quite a bit, the true factor in my opinion would seem to be the INCHES PASTED A POINT. examples
1) turning a 2" piece on a spindle ramping and it up to 3000 RPM seems to be fairly common. in this case 2" x 3.14= 6.28 x 3000 RPM = 18,840 IPP
2) In the case of turning a 6" bowl to get fast enough so you won't have the tunk-a-tunk turning Lyle talks of is about 1000 RPM 6" X 3.14 X 1000 = 18,840
Ok I've been turning some bowls around 12" and been starting around that 1000 RPM, running the numbers out would be 37680 IPP, so it would seem that if my thinking is right that on a 12" bowl blank I could start at 500 RPM and still get the same IPP AS 1000 RPM on a 6" bowl. I haven't tried this yet as the thought just became clear to me.
Any thoughts or experiences from you guys
Thanks Mike
