Bowl from Black Willow
Allan W
Allan W
This is my second time using a glue block. The bowl blank has a knot at the center of the bottom so I could not use my chuck on it because it would not hold and the Black Willow is a very soft wood.
This shows the end grain. Still have to work on getting this smoother.
This is the interior of the bowl. The fungus has been growing on the outside of the blanks which has given it some pink color at the bottom.
The bowl is about 10 inches in diameter.
My lathe is from Harbor Freight. Not the fanciest but it gets the job done. With larger pieces like this, I have to use the faceplate supplied with the lathe or a long glue black since the motor sticks out over the bed at the headstock and interferes with the turning.
Re: Bowl from Black Willow
Allan, I'm not sure, but I think I see the pith (center) of the tree in that blank. If that blank is still green I suspect it will crack around the pith in a star burst fashion. Some woods will have spectacular cracks there. It would probably be a better idea to use the blank that came from either side of this one or in the future to slice right through the pith and then take a blank from either side.
My extremely limited experience with willow was that it was very difficult to get clean cuts. You are doing well.
Allan W
Allan W
The willow was from the front yard of the school where I worked and a couple of the teachers wanted bowls from it. I still have about 6 blanks that I need to turn. Thanks to a couple of you tube videos I am learning how to smooth out the end grain with my gouges so I do not have to sand as much. After I took these pictures I worked on it some more by applying a coat of Watco Butcher Block oil and finish and let it dry for about 10 minutes and then did some push cuts with my bowl gouge across the end grain. The finish softened the grain so the gouge cut rather than tore the grain. I still have a little tear out, but I think it just adds character to the bowl.
