Anti Fog solution
Anti Fog solution
Anti Fog solution
robo hippy
Well, I swim about 5 times a week. Foggy goggles has been a problem. Usual swimmer trick is a bit of saliva on the lenses. Well, that works for a bit. I saw a product from Speedo (no, you will never catch me in one... Scary!) called Anti-Fog Solution, Composition 75% Exxene AF-091, and 25% water. Directions: Carefully apply sufficient liquid to coat the inside of the lens surface, then rinse and allow to dry. Do not rub lens once dried. Apply as needed. Well, after 2 days, no fog at all on my lenses. I might have to try it on my face mask. One reason/excuse I never wear one is because they always fog up unless I have it far away from my face. Yes, I know all the 'hot air' jokes too....
robo hippy
Re: Anti Fog solution
Jesper, Denmark
Jesper, Denmark
A little dishwashing liquid works too.
phillip Medghalchi
Reed, what brand are you suing? I have problem with mine that it gets dusty and fine dust collects on it and then it gets really hard to see clearly, someone once mentioned to use cloth fabric softener sheet and rub it on, you may want to try that see if that helps. i have to take one to the shop and try it to see what happens. I tell you what the other thing is that I have to try to clean the CA glue flings things off it too. The other solution I thought was to use the plastic polishing compounds that pen turners use on the pens to buff it out.
robo hippy
It is the speedo brand but I would think they are pretty much the same. I am always turning green wood, so no problem with dust build up. I have heard of using the dryer sheets to keep the dust off. I don't know what makes it fog proof though. I had never heard of using dish soap. I think I tried Rain-X once and it didn't do anything that I could tell. You just never know.
robo hippy
My experience with RainX
I bought it back in the day and coated my wind shield. It was great for a while. Then it turned into what appeared to be paraffin smeared on the wind shield. Very difficult to remove, but I got it off and tried again. Same thing. That was the last of that. To be fair, not sure it was RainX, but it was what passed for it when you had to be careful not to hit the T-Rex crossing the street.
two different apps
James Heaston
The dish soap you would use on the inside of the face shield as an anti-fog & dryer sheets on the outside to stop the static cling.
Jesper, Denmark
Jesper, Denmark
The function of the anti-fog remedy (and the dish soap) is to reduce the surface tension of the water. The fog is actually tiny drops on the surface. A surfactant will cause these to flow together and form a thin film instead - which you can see through.
James Heaston
But what does it smell like? ={O}
phillip Medghalchi
Mark, many moons ago (like in the Games of Throne) I got a bottle of some creamy stuff that I can swear that would be the same thing, even the same color too. It did work very well, but I couldn't think of it's name to tell John about it. I wonder now if they changed the name for it. Or, perhaps, it is the poop or content of the cat crap which is sent through chemical processing like they extract some coatings from human waste to use it in the pills shells that we take?
phillip Medghalchi
Their site doesn't look legit. I wonder what they are up to. Especially from Utah. I wonder if they catch those wild cats in the Utah deserts to make this product?
