For those who turn urns
Scott Bradley
Do you always turn twice? Do you ever turn to finish if the wood has been cut for some time but you can still feel that it has some moisture as you are hollowing? I generally turn smaller pet urns but recently ha apiece of maple that was large enough for a full sized one. I talked to a local guy here in eastern NC and he said that he always turns his large vases to finish at one time and just lets them sit in his shop to dry. It's pretty humid here. My normal method is to rough turn and microwave dry, then finish and I have only had a problem once but this was too large, so I turned to finish. I got no cracks but I did see a little movement at the mouth. It went just a little egg shaped. I did a threaded collar and top out of dry wenge and just left some clearance for movement between the collar and the body and used silicone to hold the collar to the body. I saw someone online rough turning and leaving a "lug" on the bottom to keep it from cracking while it dries. Didn't quite have enough material to do it and still have a full sized urn. Another question while I'm asking... how in the world do you price these things? I see plain old rectangular boxes all over the place between 200-350 and this is a really pretty piece of spalted, curly maple. I don't want to gouge anyone but I want to be fair to me as well.
Re: For those who turn urns
Dale Gillaspy
I usually turn to finish, but most of the wood I get is dry to start with. As far as price, I usually get i the $300 range for pet urns, and upwards of $600 for full size urns.
barry rockwell
Barry Rockwell
Another question about urns. I have turned hollow forms but never an "urn". What size do you typically make the opening? It seems like a tiny typical hollow form opening would be unacceptable for putting in ashes, whether a pet or a person.
Ralph Lindberg
Think of a hollow form, with a lid. A screw on lid usually.
It's very common to use plumbing bits for the screw part though (vrs threading wood). Sometimes the opening is in the base vrs the top
Lots recommend something like at least a 1inch(25mm) opening
Mike Stafford
Mike Stafford
I live in eastern North Carolina and I rough turn not only larger enclosed forms but I also rough turn my box blanks, platter blanks and bowl blanks.
Anytime you turn a piece of wood and it is subjected to the high humidity we routinely have here it is subject to deform somewhat. Therefore I let it equilibrate to the conditions to which it has now been subjected. It is not unusual for me to let rough outs sit for a year. They are much more stable then.
Scott Bradley
Really? Where are you? I'm in little Washington.
Scott Bradley
It's rare for me to turn to finish green too. Usually ends in disaster but I decided to give it a try this time. Again, this one wasn't freshly downed and spraying either. But I could feel the dampness as I turned it. The orientation of the project helps too. If it had been a bowl or something, I probably would have roughed and then waited. The bottom and top rims stayed very flat. The opening went a little egg shaped over the span of 7-8 weeks. It has stopped losing weight and seems to be about where it's going to be.
Scott Bradley
I've never seen one with the opening in the base. I'll have to try that sometime. I typically do an African blackwood collar and finial or something of that nature and chase the threads but the plumbing parts would save a lot of time. I kind of like doing it though.
Ralph Lindberg
Look into ABS (black) plastic threaded pipe.
Mike Stafford
Mike Stafford
I am in the "city on the rise" or at least what the city slogan used to read here in Rocky Mount.
Mike Stafford
Mike Stafford
Well, dry wood in the coastal plain is a relative turn. All the experts say that your wood needs to less than 10% moisture. I have never seen a piece of kiln dried wood that low. With our humidity if you get it down to 12-14% that is dry wood.
All wood is going to experience some seasonal expansion and contraction and nothing turned on the lathe from wood stays round year round.
Scott Bradley
Yeah, most furniture companies want less than 10%. I worked for years with a large furniture manufacturer before all the operations went to Mexico and our norm was 8% and the general rule of thumb for seasonal movement was 1/16" per ft. per season.
