Turning Green Wood
Turning Green Wood
Turning Green Wood
Roy Girolami
I was wondering what you all do when you are rough turning a green bowl blank. i mean the kind that is wet and gives you a shower as it spins. Do you cover your ways or clean up after you're done for the day? i am reluctant to turn this really green stuff on my 3520 so I am still using my old home-made bowl lathe to rough things out.
Roy
Re: Turning Green Wood
Lyle Jamieson
Lyle Jamieson
I've been turning it for 30+years. Wipe off the water and use WD-40 to stop any rust build up. You can not really hurt the bed. People in places like southern Florida or New Orleans have troubles with the humid conditions all the time. Don't worry, go for it.
don stephan
My lathe is against a white wall, so when turning wet wood I stand a piece of 1/4" plywood against the wall to catch the spray. I read of one person who rigged a shower curtain enclosure around the lathe to catch the spray. Whenever the banjo starts to drag I spray WD-40 on the ways. Wet paper towel will clean off lathe paint; don't use solvent like lacquer thinner which may melt the paint.
robo hippy
The ways on my 3520A had a nice black patina when I sold it. My ceiling and wall has a 30 inch wide reddish strip from fly off. I just wiped the ways down. If they felt a bit crusty, I would very lightly hit with 220 sand paper, then wax, or use Top Coat, a spray material, or WD-40, or 3 in 1 oil. If you left it out in the barn under tarps for a couple of years, you could get pitting, but in the shop, probably not any thing to worry about.
robo hippy
Don Orr
A while back I turned a bunch of very wet White Oak-extremely rust inducing. I would spray on WD-40 BEFORE turning, leaving the ways a little wet with it. Then just wiped it off when done and no rust.
Brad Vietje
Brad Vietje
I would (and have) also.
Funny that David Ellsworth used to tell students to turn green Oak and leave the wet shavings on the ways overnight to induce surface rust and a tiny bit of pitting, then clean up with fine sandpaper or steel wool so the tail stock and toolrest banjo would really stay where they were put.
I generally don't leave green shavings sitting around after I'm done, but I don't freak out about a little oxidation, either. My bed is developing that nice gunmetal steel look -- not shiny like new, but not all pitted, either.
I suspect the cam locking mechanisms on better lathes nowadays grip better than on the older General and PM-90 lathes, but still, a little oxidation isn't going to do any harm (and some would say it might do some good).
Safe spinning,
Brad Vietje
Newbury, VT
Roy Girolami
Thanks for the responses. I've got plenty of WD-40, so I will try that the next time I get a wet blank to turn.
Roy
Dick Hines
Dick Hines
I took a class with John Jordan and he said he wipes his ways with WD40 and lightly sands every day.
I turn mostly wet wood so at the end of the day I will spray WD 40 and then sand with 320 wet dry sandpaper. Then wipe every thing down with some dry paper towels.
Brad Vietje
Brad Vietje
I tend to spray WD-40 and use steel wool -- probably just has a finer scratch pattern.
Safe spinning,
Brad Vietje
Newbury, VT
George Balock
George Balock
Scotch Brite & WD-40 does the trick for me. I find black walnut to be particularly tough on the ways.
Mike Potts
Over the winter I was turning damp wood and a little paste wax did the trick. this spring I got hold of some fresh cut maple ( OMG do the make windshield wipers for my face shield) well the paste wax didn't do a thing, then I tried auto wax, no good either. While I think WD-40 is a great product, I went for a old stand-by I use on other tools in my shop Silicone spray. It's in the same price range as WD-40, I find it keeps rust from forming, no oil in it so saw dust doesn't stick, my banjo and tailstock slide nice down the ways, and I still get a good grip.
keep it spinning
