need so Ideas
need so Ideas
need so Ideas
Mike Potts
I had to take down a small walnut tree, due to invasion of ants in the base of the trunk. you guys might get a laugh out of the video my wife took. https://www.youtube.com/watch?v=HWeRX-sSSmw any how I chunked it up in about 3' sections and stacked them down by the shop. now where I need some help is, I've turned small walnut bowls and end grain goblets from another piece of walnut, can anyone think of other projects I could use this walnut on. the largest diam. of heart wood is only about 6" across.
Thanks Mike
Re: need so Ideas
off center
Darryl
candle sticks ala Barbra. Or maybe some goblets although most will be too big for that.
Re: need so Ideas
Great candidate for NE bowls....
Re: need so Ideas
Re: need so Ideas
Bill Howatt
Pepper mills, lidded boxes, weed pots. You can make some hollow forms, vases.
Bill
Re: need so Ideas
Re: need so Ideas
ron bauer
Whatever you decide to do make sure you get best use of the feather(s) in the crotch(es).
Re: need so Ideas
Lyle Jamieson
Re: need so Ideas
Lyle Jamieson
Find a piece of the tree that has the pith off center. Cut it longer then it is in diameter. Example, 7 inch diameter tree section cut it 10-11 inches long. Cut it in half lengthwise down the pith. This cut should attempt to leave the largest thickness of the bowl blank because the pith is not in the middle. If you are lucky the pith will now be in the middle of the bowl blank. I take the bark off...some leave it on. Mount between centers and make a natural edge bowl with the pith side at the bottom and the bark side at the top. I am careful to have the top wings edge lined up to be parallel to the table. I watch for the low edges of the natural edge to be equal or balanced to be parallel to the table too. As you rough it out move the center points to get everything lined up. Make your shape that of a shallow bowl like a football shape. The wings will be flying around and the air spaces or voids from the natural edge takes some good tool control and a bevel supported cut, but it is not as hard as you might think. It is much easier in the beginning, if you have not tried these bowls before, to keep the bowl shape shallow. The wings or rim of the bowl do not start out straight in. The rim starts out on an angle, again think of a football not a half sphere shape. This will result in a banana boat shaped bowl. Do a series of these and refine the shape to be pleasing to you. It is important to use my balanced starting point process so you can get the speed of the lathe up. Don't want to be doing Tunka-Tunka. See my YouTube clip on mounting bowl blanks. http://youtu.be/b4xIHTS0yJc
I do the same thing with the crotches. Now I have three wings flying around and the final shape is heart shaped.
Re: need so Ideas
Steven Antonucci
Perhaps some videos on tree felling?
steven antonucci
Glad you survived that one, but when the leaner hopped off of your stump, and you were under it, I bet you never moved so fast in your life?
There are some good videos on YouTube that would improve your techniques.
As far as the wood goes, walnut is pretty stable, so you can cut close to the pith without too much checking, but I think you are looking at a lot of 2x2 square stock? If you have any crooks in the tree, you might be able to turn a ladle on a couple of axis'.
Steve
Re: need so Ideas
Brad Vietje
Exactly So
Brad Vietje
For the best contrast between heartwood and sapwood, rough turn as soon as you can. Sapwood can turn an ugly grey if left too long in log form, especially if the tree was cut in spring with a lot of sap in it.
Here's one I roughed out last night -- the first of a large haul of Black Walnut, along with Mike Foster and a few others from one of our local clubs. I got nearly a ton of wood, and I think Mike drove away with more than that. Heavy stuff.
Spring cut wood is not as likely to retain its bark, but Walnut seems attached better than Maple for this time of year. Have fun, and show us what you make.
Safe spinning,
Brad Vietje
Newbury, VT
Re: need so Ideas
Brad Vietje
Re: Perhaps some videos on tree felling?
Brad Vietje
Wow -- that was pretty exciting for such a small tree! Once you had her off the stump (not recommended for all trees ;) ), you probably could have tied the rope around the bottom of the tree, and just pulled the base forward, allowing the top to fall the other way, no?
I think I wudda...
Safe spinning,
Brad Vietje
Newbury, VT
Re: need so Ideas
Brad Vietje
Re: need so Ideas
Brad Vietje
The key is to start them between centers so you can tilt and re-mount as needed to get the bowl balanced.
Safe spinning,
Brad Vietje
Newbury, VT
Re: need so Ideas
Mike Potts
Thanks Steve, That wasn't me, but my friend, yes he did move pretty fast. Problem was he didn't cut enough of wedge out of the side we want't to fall. I was in the truck and didn't check his work.
Re: need so Ideas
Thanks for the pic, Brad
Mike Potts
I was sort of worried about the transition between the sapwood and heartwood on a NE bowl. the sapwood is much softer. sort of wondered about sanding and finishing. Yes I start every thing between centers, actually just turned this 10" maple NE a couple days ago. I've gotten to the point I always single turn, I'll give that walnut a try in a couple of weeks. I've turned about 30 maple and box elder bowls in the last 3 weeks and have 16 to 20 more to go be fore starting anything new.
Thanks again
Mike
Re: need so Ideas
Re: need so Ideas
phillip Medghalchi
Mike, your friend got away with this one. I was hoping that I am not looking at some accident which was good that I didn't. You really got lucky on this one. Now, you can send your walnut logs down here and I 'll be gald to figure out what to do with it.
Look at your email, please.
