Question to John Lucas about mirrors
Alan Sweet
Alan Sweet
John, I've read your tutorial and watched your video on making mirrors. They are very good and at the right level of detail, I have a couple questions.
1. Finishing. How do you finish your mirrors? I guess I missed any information you may have included. I can't seem to get a consistent finish. Especially on the edges. I seem to have problems with the end gains and grain transition areas. Do you spray finish with lacquer?
2. Do you find certain woods provide better mirrors? Or does it really make a difference?
You may have covered these well, but I may have missed them.
Any help will be appreciated.
Alan
Re: Question to John Lucas about mirrors
John lucas
If your having problems finishing its probably not sanded well enough. If you have trouble with end grain sanding or tearout on end grain stop the lathe and hand sand those areas.
I finish mostly with lacquer because its a tough finish and easily repairable if damaged. However over the years I've used just about every finish at least once
John lucas
I've made mirrors from all sorts of woods. Is one better than another? No it's more about design however if you make just a more or less plain shape then woods with standout figure are better One trick I use is to take a piece of plexiglass 5 1/2 " square with a 4"round circle sratched in it and slide it around a board that has knots and wavy figure and locate the nicest areas that fit this circle. The. I cut these out on the bandsaw There's more waste this way but you get a nicer mirror so I charge more
Alan Sweet
Thanks, John.
