Have a question? Ask Woody!
Any body else save saw dust
You all know I turn a lot of small things and consequently I save a lot of really really small scraps. I also save some of the exotic saw dust and drill chips to be used as fillers for defects and cracks in wood. Am I getting a little too cheap?
Re: Any body else save saw dust
robo hippy
Well, whenever I sand out black walnut, I tap out the hose on a board, and scoop up what was in my sanding hood. I don't usually fill holes, but it is handy to have some on hand. I only fill on 'artistic' pieces. Shavings, well, never save them. Small scraps, if they are suitable for the pen turners, I donate them at the club wood raffle. If I didn't, my shop would be more over filled than it already is. I do have one friend from the local Saturday Market who carves a lot of pendants and small face type things, and he loves my Mountain Mahogany scraps.
robo hippy
clay foster
The person I share a studio with is OCD about saving little pieces of wood. I'm OCD about throwing them away when she's not looking.
bob davis
i have small jars of sawdust from various woods. filler for small defects
Dale Miner
I put the small pieces and shavings in the wood stove for safe keeping.
Mike Stafford
Mike Stafford
Sadly I used to collect shavings. Back in the days when I did flat work whenever I got a new species of wood in I would hand plane the edges of each board and save the curls. I had some collector jars that came from a company where I worked and I put the curls in the jars.
At one time the jars were filled with all manner of red, orange, yellow, brown, tan and black shavings. Unfortunately the majority of the woods have turned brown and the shavings are good for not much more than starting a fire.
Steven Antonucci
getting close to crazy... just saying
steven antonucci
if you store them alphabetically by Latin genus and species...you cross the line. Until then, you are OK.
S
Craig Daymon
I have a ziplock bag of Bois de Rose and of Padauk dust. Both have been used to create dyes. Keep thinking if I get enough there is a good T-shirt project appropriate for a turner. Also seems appropriate to use a wood based dye on turning projects. I suspect I don't have nearly enough to do anything meaningful yet.
Who could that be clay
robo hippy
Osage orange is used as a dye. I was at a show when a very beautiful red headed woman started talking to me about it, and bought back one of the skirts she had made that was dyed with Osage extract. It even had that glow/luster of the Osage. Beautiful! Both her and the color......
robo hippy
mine laughed.....
Ralph Lindberg
she tosses common bits in the firewood bin as easily as I do
Em...
Ralph Lindberg
We'll have a segregate the OO for that reason she has lots of "let's dye some fabric" friends
Ralph Lindberg
We has small conyainers of various dust colors just for fill; light, medium, dark, etc.
We do toss small cut-offs of the tropical, exotics, rare, etc in a separate box for possible use, vrs tossing the regular cut-offs in the fire-wood bin
phillip Medghalchi
Well, John, my favorite is walnut and I happened to be very much drawn to it. for what ever strange reasons I hae many shades of walnut dust and shavings. I am not sure how it happens but almost every walnut I have worked on has different shade of brown color to it I have it from almost very brownish black to almost mauvish color dusts. I douse them to fill cracks and voids. One thing I like about them that with the varieties of the color I have I can fill voids to the exact color match that is in the wood. and I use the shavings (haven't done it yet) so I can embellish an accent ring on a bowl or lid. If you take your time and lay them on and then glue them you can have an interesting effect. I did one here on this piece.
to this by just using the walnut saw dust
Dick Hines
Dick Hines
Sure do. I use the little Dixie cups to hold the dust from bowls I turn. I also save tons of cut offs. I have 6 big plastic tubs full of cut offs. They come in handy when turning ornaments.
Blackwood and any Australian burl is to costly to to toss in the trash.
For filling voids...
Craig Daymon
...try some Strait-Line chalk. I used black mixed with epoxy to fill a fairly large void near the rim of a 20" platter I turned. Worked great and dirt cheap. About $1 for 8 ounces from Home Depot. That's enough to fill a whole lot of voids.
terry gearhart
Re: For filling voids...
terry gearhart
Yes, I'm guilty, I have baggies of the stuff. When I have a small void, I simply toss the chips/shaving into a spice grinder and grind it to real fine dust, fill the void and add CA over top with accelerator.........works great
Re: Who could that be clay
clay foster
I can't tell you. Then she would know who had been throwing away her little pieces of wood.
ihmserv
since I do a lot of segmenting and occasionally a joint doesn't quite work out. I keep containers of fine dust for filling the gaps.
have taken chips mixed with epoxy and contrasting dust to make up pen blanks.
small pieces, must be 2 five gallon buckets in the shop, why I don't know.
ian
phillip Medghalchi
There is new syndrome added to the medical dictionary. WTSDHD. .......................................................................................................................................................................................................................................
Wood Turner Saw Dust Hording Disease :D :b
Philip F Duffy
U betcha! P.
Yes, yes I do.
Don Orr
As most others have said I keep a few colors of saw/sanding dust on hand just in case. I also keep all the small offcuts of special woods. I make beads and similar from them.
My favorite use for shavings is,
Keith Newton
to use them as ribbons for decorating the wrappings when a nice piece is inside for a gift. I try to keep it simple, by using using brown craft paper, then a simple plane shaving around under the bottom, maybe another for curls, then those little ones could be used like sprinklings on a cupcake.
Someone getting a gift wrapped like this will know there is something special inside, and will be almost crazy with anticipation if it has to sit under a tree for a spell.
Jennifer Indy.USA
Hey! I'm just now reading this! No wonder I can't find my bits and pieces.
Re: My favorite use for shavings is,
Ron Pemberton
I save my sawdust on the floor of the shop. That way I can easily see what I have
