Have a question? Ask Woody!
Ingredient Bowl
Ingredient Bowl
Allan W
Ingredient Bowl
Allan W
This is the first of a set of four ingredients bowls I am making. The bowls are 2 inches high by 3 1/2 inches in diameter. The top is walnut with a band of redheart and the bottom is hard maple.
Re: Ingredient Bowl
Re: Ingredient Bowl
Blondterror
very nice and a great idea for serious cooks. I need to make some for our kitchen... and for Xmas gifts next Dec
Re: Ingredient Bowl
Re: Ingredient Bowl
Alllan W
The next set I am going to try and make them a little larger in diameter and not as high. I did have a little staining of the maple from the redheart when I was sanding before the sanding sealer.
Re: Ingredient Bowl
Re: Ingredient Bowl
Blondterror
that dust staining issue is a drag... I get it as well with my segmented bowls esp when mahogany or ipa is next to maple... trick is to sand the maple last very carefull with 320 grit and careful use a rag to collect the dust
Re: Ingredient Bowl
Brad Vietje
Will Sanding Sealer Help?
Re: Ingredient Bowl
Allan W
Re: Will Sanding Sealer Help?
Allan W
That is something I didn't do. This is the first time I worked with Redheart and did not know it would stain. The stain looks like it is part of the maple so it is not a big problem on this project, but would be if it were more pronounced. I will have to remember to try it the next time. Thanks.
Re: Ingredient Bowl
John lucas
Sorry im late on this thread been traveling. I use thinned lacquer as a sealer Shellac works just as well. Apply sealer and then sand. Apply more sealer and sand with the next grit. Blow the dust off between each sanding. The sealer helps keep the dust from getting stuck in the pores
Re: Ingredient Bowl
Bart Leetch
What is the final finish coat & how many coats. I presume these would be used for dry ingredients only.
Re: Ingredient Bowl
Maybe?
Geoff Whaling
Are the problem areas where the end grain is exposed? Of course!
I have a similar issue with New Guinea Rosewood a very close relative of Padauk in my linear laminations because most of the viewed areas are end grain. Some of the NGR can be quite oily particularly the deep orange reds. My problem is I usually have a thin very white contrasting veneer right beside the NGR.
The thinner/solvent in the nitrocellulose sanding sealer actually carries the fine dust and disolves the natural oils. Using sanding sealer can at times be a worse choice than simply wiping or even blowing off the fine dust.
The problem becomes worse the longer you delay applying the sealer. Applying sealer at your lowest sanding grit say 180 is far better than deciding to use it at 400. Then of course you deal with clogged sand papers.
I prefer to blow off the dust, then use shellac as a sanding sealer from about 400/600 grit as I usually can start sanding on my small linear laminated pieces at 400/600 grit. I strive for that quality finish off the tool on small pieces. If I know I have a very problematic piece of NGR I use a cheap airbrush to apply the shellac.
Re: Ingredient Bowl
Allan W
Allan W
The finish on these is Watco Butcher Block oil and finish. I have 3 wipe on coats on these, sanded to 1000 grit between coat two and three. Ingredient bowls are usually used for dry ingredients or semi wet such as onions, etc.
Re: Ingredient Bowl
Allan W
Re: Maybe?
Allan W
Thanks for the information. This was my first project with different woods and I didn't even think of using air to clean it up. Will try that next time.
Re: Ingredient Bowl
Bart Leetch
Thanks for the info.
Is it possible to turn these in a clear or clear colored acrylic?
Where might I find the material?
Re: Ingredient Bowl
Allan W
Allan W
I see no reason you couldn't turn them from acrylic. I did a search and found some 2 1/2 inch blocks on E bay but did not find any from any of the regular retailers. Maybe someone else will know of a source. The other possibility is to make your own blocks using epoxy and your own form. I saw a video on YouTube on making epoxy bowl blanks using wood cut offs a couple of days ago, but couldn't find it now.
Re: Ingredient Bowl
Stuart Johnson
Is this the one?
Re: Ingredient Bowl
Allan W
Allan W
That's the one. Thanks for the link.
Re: Ingredient Bowl
Bart Leetch
Thank you the video was very informative.
