Now is the best time of year to remove the bark,
Keith Newton
For any of you that harvest your own wood, and live in the Northern hemisphere, Springtime is the easiest time to do that.
After being dormant through the Winter, the cells just under the bark devide and are very thin walled, making them more fragile than any other time.
I just finished debarking some thick Cherry slabs that I sawed up on my mill. Even though the logs were harvested back before I fell on the ice and broke my ribs, the have been getting plenty of rain, keeping them alive.
I was using a waffle faced 20oz framing hammer to knock it off. I strike the bark at about 45*, while keeping the face pretty flat to the face of the bark. The waffle face will get enough traction to shear those new cells underneath.
If you hit with the hammer face tilted to the wood, but in line with the swing, the chance of bruising the natural face is likely to show up on that natural surface which you are after.
After knocking the thick bark off, I followed that by scraping off some of the thin remains with the corner of a hardwood scrap, then Scotchbrite dipped in lemon juice.
Re: Now is the best time of year to remove the bark,
Brad Vietje
.and the worst time if you want to retain the bark
Brad Vietje
True enough, Keith, but for those who want to make natural edge or "live edge" bowls or other forms, Spring cut wood creates a problem for exactly the same reason -- the bark is so easy to peel off.
If you don't want the bark on there, Spring cut wood can be great to work with -- sometimes the bark almost slides right off.
Safe spinning,
Brad Vietje
Newbury, VT
James Heaston
Okay Keith I'll bite - why the lemon juice?
I'm not sure about the chemistry, but
Keith Newton
There may be sugar in the sap, which quickly turns brown when exposed to air after exposure, especially around where the hammer impacted the outer bark.
Back in the early nineties, I built a circular stair around a hollow Silver Maple tree that I stripped the bark from. While getting it off, I could see it turning very quickly, and wondered what I could do to stop it. Then I remembered that my Mom would dip the banana slices in lemon juice before putting it in her fruit-salad to keep them from turning. I suppose the citric acid must change the ph or something.
I don't know why I didn't think to try vinegar, but maybe next time I will. I usually have a quart if Real-Lemon juice in my frige though.
