something completely different (Tormek related)
Steven Antonucci
Steven Antonucci
I purchased stone #3 on my Tormek last year, and I struggled getting #2 off the spindle. It had rusted on, and generally speaking I was sure it wasn't coming off in one piece. I was right, and it split in half.
Being frugal, I kept both halves for an idea that I had. I was going to resaw them into small water stones to give to the club...but instead I just split them into rough pie wedges with a hammer and chisel. The first pie wedge was brought over to the grey wheel on my grinder to see if I could grind a flat face to make a rubbing stone for my carving axe, and I was surprised to find out how easily I could grind it flat. My axe is now shaving sharp.
So I had about a dozen or so various sized wedges, and I plan on giving them to my club members. I had another idea, which was to roughly grind a round shape, soak them in water, and then polish the flute of my gouges. Not only does it only take about 5 minutes to get a rough shape on the stone, but it only takes about a minute of rubbing the flute to bring up to a1000 grit surface.
And yes, you can feel the difference in edge and it is worth the investment of 20 minutes or so to go over your flutes :)
Steve
Re: something completely different (Tormek related)
Steven Antonucci
before and after...
Steven Antonucci
Rob Wallace
You could also flatten the faces.....
Rob Wallace
....of the pieces by lapping them on a piece of 80 grit abrasive taped to a glass plate or flat floor tile. It won't be as quick, but it would be a lot less messy than a grey wheel on a grinder, and would potentially be a lot flatter. I lap my waterstones on silicon carbide wet-dry abrasives "water-adhered" to a glass plate - this does an excellent job of leaving a very flat, clean surface. The water helps carry away the swarf, and this process is never dusty; the same would be true in this case if you wet the wheel before flattening it.
This is a good idea, and I also like the idea of the flute polisher. Now a used Tormek stone is on my scrounging radar....
Rob
Steven Antonucci
Quick report
steven antonucci
I just grabbed a piece of old 180 grit (still pretty good) and a partially flattened stone... Lapping by hand will probably work to maintain the stone once it is flat, but it's really slow compared to the grinder wheel. Granted, I cannot get the stone flat on the grinder, but I see the hybrid approach of rough on the grinder, flat on the paper working.
If you send me your address via a FaceBook message, Rob, I can mail you a piece to play with
Steve
